fan on motor vs no fan and higher temps and voltage
I was running TC a few years ago with a fan 'behind' the motor, and noticed it only dropped 10 degrees, 15 at most.
a 30-40mm fan consumes lipo energy, how many millamps/amps, I don't know.
Question; do you think there is a significant reduction in lipo voltage running just 1 fan? I know most people run fans now, especially in blinky.
is it just better to get full voltage going to your motor, and letting your motor run 10-15deg warmer?
I had heard in the tekin data logger thread that someone who had ran 2 fans, dropped like 0.3 or something similar volts, just from running the fans. And as soon as they switched it off,the lipo voltage went back to normal.
I havnt had a chance to do any data logging yet, or TC for that matter. Just curious, if I get back into TC again.
sunon.....they had the best fans available 2-3 years ago, and they are prob just as good as the r1/wtf fans of today.
But yeah, sounds like 1 fan is the way to go.
it's funny how trends go.....not long ago most people were running heatsink/fan combos.....now its just a fan without the heatsink.
Do you just wire the fan directly to the battery leads to get 8.4? I tend to leave mine connected more than just before my run.
I believe my receiver is rated for it (coming from nitro lipo directly to the receiver is fine for it and the servos) but I believe my Orion ESC is only outputting 6v
Not sure about the fan the OP is running but a good fan can lower temps as much as 30F on a warm day for a single 6 minute run.
Heat fade will kill power more than the very tiny voltage loss from the fan.
