VBC Racing D08
#91
You can start with 5.5 in front and 0.5 in rear.
http://www.rctech.net/forum/13909286-post330.html
You can ask Bjorn or myself for setup help in Belgium
Nicolas
#92
[QUOTE=nicoo2k4;14364754]Hello Sven,
Ok tkx Nicolas.
I assume 0.5mm under the center of the bow of the hubs in rear.
Still few days till, I can start the build
Ok tkx Nicolas.
#93
[QUOTE=Svendc;14365410]
You are correct!
If you are using Volante tires,I can send you my start setup. Car was easy, just need more steering
Hello Sven,
Ok tkx Nicolas.
Ok tkx Nicolas.
#94
[QUOTE=nicoo2k4;14365474]
ok nice that would be fine. i've got a start to work around than. The last batch volantes have indeed less steering, grip, need less harder damping in comparision with the old volantes, but the wear is less.
sven
sven
#95
In attachement
#97
#98
Those are the rear settings on the setup sheet, longest links in the rear. 2nd shortest links in the front.
#99
#100
Counting down, my Car kit will arrive early next week. so this weekend gonne prep a new dodge dart. Are there VBC stickers in the kit?
gtz
gtz
#103
new post old car d06
Known problem. With right rear hub toe in. Blocks used co e30 for 3 deg toe in. Left will be 3 and right side be at 4. Suspension arms installed way manual says. I flip the right suspension arm opposite And now I get 3 deg on right side. Is there anything wrong with running the arm that way? Or should I do the left rear the same way?
#104
Known problem. With right rear hub toe in. Blocks used co e30 for 3 deg toe in. Left will be 3 and right side be at 4. Suspension arms installed way manual says. I flip the right suspension are opposite And now I get 3 deg on right side. Is there anything wrong with running the arm that way? Or should I do the left rear the same way?
#105
