Like Tree8Likes
Old 05-15-2017, 03:22 AM   #541
EDWARD2003's Avatar
Originally Posted by jay m View Post
What surface you racing on interested to see the setup
http://site.petitrc.com/reglages/vbc...Arena20170514/
After reading Ryan's book a few times I decided to make some changes to the dampening package. I changed the shock lengths between the front and rear, added some bump steer, took out some front camber, and boom the car was on rails.
Please note this is not black CRC carpet.
I would suspect this setup to be too edgy for black CRC carpet. It's worth giving a try and would like to hear people's feedback.
EDWARD2003 is offline   Reply With Quote
Old 05-15-2017, 01:02 PM   #542
Johnny Wishbone's Avatar
Originally Posted by EDWARD2003 View Post
VBC Racing Wildfide D08 - Edward Pickering - Yatabe Arena - 14.05.2016
Hi Edward,
I've been running almost the identical setup on my D08 and its dialed. The only difference is I run the SMJ Red front springs and the SMJ Blue rear springs.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-15-2017, 09:45 PM   #543
Professor's Avatar
Hi Edward
how are you measuring your droop & what are your shock lengths ??
just asking as we have a carpet race coming up & carpet is all new to me we usually on run on asphalt,
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 05-15-2017, 11:20 PM   #544
EDWARD2003's Avatar
Originally Posted by Professor View Post
Hi Edward
Droop is measured over ride height.
I measure the whole shock. My starting stock length is 57.20 mm.
However my current shock setup has changed to 57.70 mm front and 57.40 mm rear.
Old 05-17-2017, 06:47 AM   #545
hi edward
Why do you run such a hard rear spring and how does it affect the car?
Chris_morrison is offline   Reply With Quote
Old 05-17-2017, 05:52 PM   #546
EDWARD2003's Avatar
Originally Posted by Chris_morrison View Post
hi edward
I wouldn't consider SMJ Silver a hard spring.
SMJ1000: SILVER LINE SPRING TS SET (Short/3pairs) | SMJ-RC
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
Old 05-17-2017, 06:53 PM   #547
running 3.0 sliver rear springs
i run 2.6 rear with the same front springs what is the advantage?
Old 05-17-2017, 08:50 PM   #548
EDWARD2003's Avatar
There are several reasons why I used Silver rear spring. Tire choice, traction level, roll centers, and driver preference. I tried using SMJ Blue, but there was too much chassis roll making it slow and sluggish in the infield. Easy to drive but not fast. I went to a harder spring (Silver) to tighten up the rear end and make the car transition faster through those sections.
I highly recommend you to buy Ryan Maker's book. It will help answer questions such as this and more.
Professor likes this.
                 VBC 12M - D08 - FX
Old 05-17-2017, 08:58 PM   #549
I bought his book mostly on your recommendation via your review on your YouTube channel I am currently reading his book.
Thanks for your quick reply
EDWARD2003 likes this.
Old 05-18-2017, 12:20 PM   #550
aracefan's Avatar
Trader Rating: 38 (100%+)
Hey guys, just ordered a new D08 DE from Alex at GripworksRC just a couple of days ago, and am wondering if there are any option parts needed that don't come with the Dynamics Edition?? When I will have the opportunity to run this it will be on the CRC black carpet.
Really excited to get this chassis in and put together.
Also, I know I've done it before - but THANK YOU, EDWARD for doing your how-to/setup videos for the various VBC cars, helped me quite a bit with the 12M and the FX.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is online now   Reply With Quote
Old 05-18-2017, 02:15 PM   #551
Probably the SMJ silver springs, progressive and linear. Also the 2.0mm isotropic top deck. If your running mod, possibly the front deck post, but if you go to the none floating steering setup, the post no longer works. Not sure if the dynamics comes with the aluminum chassis, but for black carpet its almost a given. You may also consider the harder plastics like the gold or reds.
aracefan likes this.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-18-2017, 03:02 PM   #552
Trader Rating: 18 (100%+)
Originally Posted by phatboislim View Post
I hate to ask this in the D08 thread...but does anyone know of what parts are swappable with what brand or the D08/09 with the D06?
i'll just ask this again.....
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is online now   Reply With Quote
Old 05-18-2017, 03:26 PM   #553
I've never had a D06 so I can't help you there, but DBM has a D06 and a D08. Hopefully he will see this and chime in.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 05-18-2017, 09:32 PM   #554
EDWARD2003's Avatar
That's difficult. I don't know. The car kits and parts have gone through some big changes.
Old 05-18-2017, 09:40 PM   #555
The arms, front and rear hubs, steering blocks, inner and outer hinge pins, diffs, front spool, belts, are all the same ... the plastics however are WAY better now than the stuff that was on the 06 car. I've had silver and gold compound plastics and have been very happy with all of it.
phatboislim likes this.
ChadBlanton is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
