Like Tree8Likes
Old 04-24-2017, 08:31 PM   #526
Trader Rating: 15 (100%+)
Originally Posted by Johnny Wishbone View Post
The D09 lower bulkheads will bolt to the D08 chassis and if you use the D09 top deck or the VTD it will work on the car. The rear upper bulkheads on the D09 look like the shock tower placement is slightly different. (This explains why my bodies mounted on the D08, need the holes elongated to fit the D09). Again to confirm, the D09 top deck screw spacing is about 1mm narrower than on the D09
Excellent thanks for that just what I wanted to know. Hopefully the d08 upper bulk heads fit the d09 lower bulk heads allowing for more camber link adjustment. And keeping body mount holes the same. Cheers
jay m is offline   Reply With Quote
Old 04-25-2017, 08:22 AM   #527
Johnny Wishbone's Avatar
They certainly look like they will work, I never tried them but everything looks like it will bolt right on.
The combination certainly looks like a interesting combination although I'm not sure its cost effective (4 lower bulkheads, and one of the top deck options for a D09). I personally like the D08 motor mount over the D09 and this would get the best of both for me.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-25-2017, 09:02 PM   #528
Hey I messed up measuring the D09 bulkheads on the D08. I never noticed, but I had all the furthest out holes for the bulkheads lined up, but didn't notice that the inner holes are about .05mm closer together than the D08 bulkheads.
Its so close but now I don't think it will work.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-26-2017, 12:08 AM   #529
That was my thoughts would be easier changing out spurs with the vtd that's for sure
Old 04-27-2017, 01:15 PM   #530
aracefan's Avatar
Trader Rating: 38 (100%+)
Thinking about picking up one of these kits (VBC D08 DE) to run USGT with. I am not very familiar with VBC TC's and am wondering if I should save up for the D09, or if the D08 DE would be sufficient. I'm not the best driver out there (obviously) but do okay and mainly just want to have fun. I have some VBC cars (12M, Lightning FX & Lightning10) and really like them...
What are the differences between the 09/08 chassis'?
TIA
-Barry
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is online now   Reply With Quote
Old 04-27-2017, 02:11 PM   #531
TIA
-Barry
If DE means the dynamics kit, then the differences are, lower bulkheads (with slightly different screw hole location), different top deck for better access to the pinion setscrew, motor mount and the screw tunability of it. Also it has a different floating steering assembly.
The none dynamics had the regular length shocks, high shock towers, and a slightly different rollbar attachment, 6 screw motor mount adjustment.
Either car works well. I think the D09 roller may be slightly lighter.
There is a D09 Dynamics coming out in May, which usually has a lot of option parts as standard package, sometimes includes both chassis options, all for a really good price.
So I'd wait and see what that one will be first.
aracefan likes this.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 04-27-2017, 02:26 PM   #532
aracefan's Avatar
Thank you, sir, for the quick response. Def gave me some stuff to think about.
Old 04-27-2017, 06:14 PM   #533
VBC D06 and D08 F/S your interested.
freebird is offline   Reply With Quote
Old 05-01-2017, 07:13 AM   #534
1shnot's Avatar
Originally Posted by EDWARD2003 View Post
I too had this issue for sometime. I was racking my brain trying to figure out how to fix it. I found out that the upper bulkhead caps have a big influence on the spacing on the lower bulkheads. If this is done wrong this will cause the upper deck to tweak and ultimately the chassis to have a tweak.
Take the upper bulkhead cap assembly off.
What I did was I loosened the shock tower screws allowing the upper bulkhead caps to be loose. Then I set the upper bulkhead spacing for 19 mm and carefully tightened the shock towers screws down in a X pattern. Then I take the other shock assembly and place it on top of the already completed one and used it as a template.
I then loosen the lower bulkheads to prepare for the upper assembly to be mounted to it.
Once both upper cap assemblies are finished I then place them on the lower assembly and screw them down.
I don't screw the lower assembly to the chassis just yet. I then place the upper deck on and screw it down slightly. What I mean by this is that there should be some up and downward movement of the upper deck.
Once the two bulkheads are loosely connected by the upper deck I then flip the chassis upside down. (Take off body posts for this)
I then have the chassis upside down and using the shock towers as points of contact on a flat surface. I then tighten the the lower bulkhead screws down. Flip the chassis over and check to see if the upper deck falls under it's own weight. If it dose then the chassis is good to go.
Thanks for that Edward,
How did you or everyone here get the spacing for the bulkhead at exact 19mm?
Any other Diaphragm+O'rings from other companies? we can use?
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 05-10-2017, 07:56 AM   #535
EDWARD2003's Avatar
Relfex Racing for diaphragms and Yokomo blue o-rings are nice.
I'll have a new setup posted for the D08.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 05-10-2017, 08:19 PM   #536
I believe this setup is now available.
Arn0 is offline   Reply With Quote
Old 05-10-2017, 09:04 PM   #537
EDWARD2003's Avatar
VBC Racing Wildfide D08 - Edward Pickering - Yatabe Arena - 10.05.2016
Yes, thank you for posting.
The D08 is using D09 FR suspension mounts. These mounts are slightly lower then the standard D08 mounts. If the progressive Red SMJ springs are too much, then simply switch out to SMJ pink.
                 VBC 12M - D08 - FX
Old 05-11-2017, 06:51 AM   #538
Trader Rating: 18 (100%+)
I hate to ask this in the D08 thread...but does anyone know of what parts are swappable with what brand or the D08/09 with the D06?
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is online now   Reply With Quote
Old 05-14-2017, 05:53 AM   #539
EDWARD2003's Avatar
Did some further testing and improved upon my previous setup I posted. I would say this is the best the D08 has ever performed. It was super easy to drive, had lots of steering and was very stable. I was easily chasing down BD8's, Xrays and Kyosho's.
It's worth trying out.
The setup will be posted soon.
                 VBC 12M - D08 - FX
Old 05-15-2017, 12:39 AM   #540
What surface you racing on interested to see the setup
