Like Tree9Likes
Old 01-26-2017, 08:07 AM   #496
patorz31's Avatar
Originally Posted by azzrc View Post
I've posted in on vbc racing fanatic on Facebook if you want to have a look
With photos
It's Not a D09 chassis. It looks like the Smokem Racing Prototype chassis I had....
Northern Alberta Scale Car Auto Racers Pres. and Promotions
SCHUMACHER RACING Canada,TEAM POWERS, Mon-Tech,Sanwa
patorz31 is online now   Reply With Quote
Old 01-26-2017, 08:56 AM   #497
Johnny Wishbone's Avatar
Originally Posted by 1shnot View Post
That's NOT a good news!!! LOL
Anyone swap out the ball cups with any other companies? around here VBC does not exist.. I hoping associated will work, since I have used 5mm ballstuds.
I use the stock parts which work very well, not sure why you'd want to change them, but I think you'll have to do both, the cup and ball as the VBC is pretty big compared to most.
Not sure why there is interest in the chassis swap deal, I think the majority of the flex adjustment is achieved via the motor mount itself, so just changing the chassis plate sort of defeats the whole deal.
This place, https://gripworksrc.com/ has lots of VBC parts, in Western Canada. Fast and inexpensive shipping.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-26-2017, 08:57 AM   #498
I agree, that is not a D09 chassis, more of a D08 if anything.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-26-2017, 09:09 AM   #499
1shnot's Avatar
Reason I'm looking at other company is on my last race I have bent the turnbuckle and I want to race again ASAP and didn't want to wait for the shipping.. just wanted to walk into a hobby shop and pick up what is available.. and I also have snapped off a ballstud (gorilla fist..lol)so I replaced it with Team associated 5mm ball stud .. nothing against VBC stuff.. obviously I drive one!
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 01-26-2017, 09:12 AM   #500
Trader Rating: 30 (97%+)
what size turnbuckle do you need I have 3x32 extras, if you want, I am in Cambridge Ontario, and have extra ball studs as well
zaraz is offline   Reply With Quote
Old 01-26-2017, 09:17 AM   #501
1shnot's Avatar
Those are the ones I need... but I'm thinking to try Titanium this time..
ball studs I already changed them with Team associated "heavy duty 5mm"
-Fast cats
-T.O.P
-Airtronics
Old 01-26-2017, 09:36 AM   #502
The ballstud size seems to be proprietary to VBC, haven't seen anyone else that uses that size. The rest of the hardware is pretty standard sized metric, although lengths could vary.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 02-12-2017, 06:51 PM   #503
Trader Rating: 15 (100%+)
Out of interest do any other diffs fit the d08 or diff internals from other makes?
jay m is offline   Reply With Quote
Old 02-17-2017, 07:35 PM   #504
Heathen's Avatar
Just bought a D08 and it leaks. After rebuilding it three times it still leaks. My D07 is going on three full seasons and doesn't leak a drop. Got any tips?
Thanks in advance.
Addicted since 1995!!
VBC D07, VBC D08, MTS FF Pro, Calandra 1/12 XTi, SCMT Warpath, AE RC8B3e
Heathen is offline   Reply With Quote
Old 02-17-2017, 08:04 PM   #505
Thanks in advance.
I leave out the white o-ring and use a little green slime around the seal. It stays pretty tight, but honestly I refill my diff quite often trying different weight oils
ChadBlanton is offline   Reply With Quote
Old 03-01-2017, 09:56 AM   #506
DBM
Thanks in advance.
I used fine grit sandpaper (400 grit) on a hard flat surface to lightly sand the mating surface on the diff housing, and used green slime on the orings and mating surface. I've not had a leaky diff in any of my 4 vbc's. I'm not sure how my d08 diff doesn't leak though, cause the outdrives have a f as ir bit of play in them after running 400 packs through it.
VBC D08, D07, D06 Dynamics, Ghost EVO, Lightning 12v2, Serpent S100LT, Speed Passion SP1, Tamiya M05v2
DBM is offline   Reply With Quote
Old 03-01-2017, 10:09 AM   #507
DBM
2 minutes of work on the servo mount and i was able to come up with a d09 style center link.
Old 03-01-2017, 10:22 AM   #508
Does anyone know if the new VTD for the D09 will work on the D08? If so, I'd be interested in trying it out.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 03-01-2017, 10:40 AM   #509
I don't think it would be a straight bolt on option without modifications. The bulkhead screws are spaced closer together. At least thats what I found when I tried a D08 deck on the D09. I have one coming so I can try it on both cars and report back.
I do think they would have stated that it would work on either car if possible though.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-01-2017, 08:03 PM   #510
VBC D06 and D08 F/S if anyone knows someone interested.
freebird is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Blue Sky
