Like Tree8Likes
Old 01-12-2017, 10:21 AM   #481
Originally Posted by AlexPate View Post
I can get the d08 dynamics still.
I have an order that is about to ship from hk soon let me know
Gripworksrc@gmail.com
I had asked you about an 08 kit before I bought this one. Wanted the cheap deal. Did the Dynamics go on clearance?
GimpyGolden is offline   Reply With Quote
Old 01-12-2017, 10:25 AM   #482
AlexPate's Avatar
Trader Rating: 19 (100%+)
Yes, I didn't realize they still had some.
Contact me for pricing.
AlexPate is offline   Reply With Quote
Old 01-12-2017, 03:54 PM   #483
NITTO550's Avatar
The castor blocks from xray are not a direct fit, i never said they were. You will need to change the sleeve to xray sleeves and some sanding and shimming. I know this because ive used them before. Modification of your ride is not a crime, ive seen plenty of pro drivers using products outside of their sponsors. If you think using a different part will make you faster then do it.
NITTO550 is offline   Reply With Quote
Old 01-17-2017, 06:29 PM   #484
Default DO8 BELTS
Hi guys dose anyone know if any other brand of belts fit the D08
Thank you
azzrc is offline   Reply With Quote
Old 01-18-2017, 06:26 AM   #485
DBM
Thank you
Tamiya 418 has the same length of fron belt as the D08 (507) although I've never tried one.
DBM is offline   Reply With Quote
Old 01-18-2017, 04:44 PM   #486
Thanks for the info mate ill give one a go
Old 01-18-2017, 10:36 PM   #487
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
if you're having issues with c hubs and you have not sanded the wheel axle ends, I highly recommend it.
click trak and other track walls with gaps between sections will cause damage at some point.
sand them down until they're about 2mm from the hex, then round them so they'll "skip" through the cracks when you decide to rub the walls.
a dremel with the sanding drum is great for this.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 01-22-2017, 09:32 PM   #488
Default D09 chassis
Has anyone run aD09 chassis on a d08 yet if so was it any good
Old 01-23-2017, 08:33 AM   #489
Johnny Wishbone's Avatar
The motor mount is totally different so it can't be done.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-23-2017, 10:39 AM   #490
It can be done i have done it just haven't run the car yet it was a straight swap but like you said it has a different motor mount style but the D08 motor mount still fits
Old 01-23-2017, 04:56 PM   #491
1shnot's Avatar
Good News!! was looking at D09 Alum chassis....
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 01-25-2017, 07:44 AM   #492
I have overlayed the D08 to the D09 chassis, and without modifying the existing D08 mount, it will not work. Besides having to either remove the locating pins from the mount or drilling the D09 chassis for the pins it won't work. Even if this is done, only one screw will line up properly and the forward mount screw will be 1.47mm out of place. I guess you could try running with just one screw holding the mount in place, or force the forward screw in, but then you'll have a bowed chassis. Also without drilling additional holes, you'll loose the ability to add extra screws for flex settings.
If you managed to just screw this on without modifying, I'd like to see it, as I just don't see it being a straight swap.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 01-25-2017, 02:29 PM   #493
1shnot's Avatar
That's NOT a good news!!! LOL
Anyone swap out the ball cups with any other companies? around here VBC does not exist.. I hoping associated will work, since I have used 5mm ballstuds.
-Fast cats
-T.O.P
-Airtronics
Old 01-26-2017, 02:33 AM   #494
I've posted in on vbc racing fanatic on Facebook if you want to have a look
With photos
Old 01-26-2017, 06:08 AM   #495
Trader Rating: 30 (97%+)
3 racing ones fit perfectly, they have the same size ball cups, in dirrerent colours, red looks really good on this chassis
zaraz is offline   Reply With Quote
