Like Tree8Likes
Old 09-16-2016, 12:19 PM   #406
Originally Posted by svturtle View Post
Hi guy's, just bought an VBC D08 Dynamics edition.
I have 2 questions.
1, What scenario's would the mid flex motor mount post would be used? or even the optional solid post?
2, Are the TBBS shocks better for asphalt conditions or the original D08 shocks.
Track is outside asphalt, a little bumpy, low to medium grip.
1 .think it's for high grip carpet haven't found a track where it works outside for me yet
2. The kit shocks are good but 4 holes make them to soft buy and fit 3 holes with 400-450cst oil (400 my fav)
As for better the normal d08 shocks if it's really bump the larger shock should perform better but if it's not too bumpy the shorter ones are just as good but better on smooth tracks
tcboy1983 is offline   Reply With Quote
Old 09-16-2016, 01:50 PM   #407
AlexPate's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Professor View Post
I have race the d08 on various outdoor/grip level tracks here in oz & have found the flex post solid or flexy one of no benefit so I don't use it
have tried the bb shocks on the same as above & found the originals to work better on our track types
but you may want to do comparison's yourself at your particular track
if you look on rc pettit site at the set up that ryan maker has for the d08 you will find this will work pretty well anywhere with just a minor change here or there
hope this helps
With Ryan makers setup try to make the rear wider. This will help with rear traction. Ryan drives in Australia where it's super hot and you can get away with less rear traction
AlexPate is offline   Reply With Quote
Old 09-16-2016, 06:24 PM   #408
gigaplex's Avatar
Ryan doesn't drive VBC anymore. It's also not that hot in Melbourne most of the year, it's only super hot for a month or 2.
gigaplex is offline   Reply With Quote
Old 09-16-2016, 08:10 PM   #409
Got hold of Ryan himself, gave me some shock tips to start with.
I'll start with that and work from there!
Just in case anyone else is interested, here's what he recommended to change from his basic asphalt setup when using the TBBS shocks.
VBC red springs and low alloy spring retainers
or
Xray 2.5-2.8 progressive springs
or
SMJ 2.5-3.0 purple progressive springs and #2 on shock tower.
Going to try the SMJ route to begin with.
svturtle is offline   Reply With Quote
Old 09-16-2016, 08:14 PM   #410
Think you're on the money with this
Old 09-20-2016, 10:31 AM   #411
1shnot's Avatar
So I ended up pulling a trigger on Dynamics edition...
So the way it sounds, we don't have a fix for the hinge pin/insert fix, Should I just shave off just a 1mm? does this work for all of you?
-Fast cats
-eXpress motorsports
-T.O.P
-Airtronics
1shnot is offline   Reply With Quote
Old 09-20-2016, 11:04 AM   #412
AlexPate's Avatar
Just consider it an expandable part, and motivation not to hit things I've only broken a few over the course of a season. Chances are you will have bent pins before you punch out the inserts
Alex Pate. www.gripworksrc.com
Motiv Rc, Hobbywing, ORCA, Protoform,
VBC RACING, XRAY, ROCHE, AWESOMATIX, TEAM ASSOCIATED,
ARC,CRC,AVID,MCKUNE DESIGN, PROLINE, JCONCEPTS, GFORCE, MACLAN, R1WURKS
Old 09-20-2016, 11:37 AM   #413
1shnot's Avatar
so... don't shorten it? and don't hit things.... got it! LOL
-Fast cats
-T.O.P
-Airtronics
Old 09-20-2016, 11:43 AM   #414
AlexPate's Avatar
You can shorten it if you want, I actually don't know if it will make a difference.
But for the cost of the part relative to say a c-hub I'm ok as the d08 only really breaks when you deserve it
Old 09-20-2016, 03:04 PM   #415
1mm shorter pins and this.
Rodney Racer is offline   Reply With Quote
Old 09-20-2016, 06:47 PM   #416
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Ive run my car all summer and I have never had an insert failure.....
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 09-21-2016, 02:44 AM   #417
I'm actually up to this part of the build now. How would I know if I may need to shorten the pins?
I'm guessing just fit inner hinge pins into mounts/inserts (minus arms etc) and look for a little forward/back freeplay so as not to have a tight fitting pin?
Old 09-21-2016, 05:04 AM   #418
EDWARD2003's Avatar
There's no need to go through all the fuss with cutting down the pins by a few mm. Just run the pins at normal length. The car is quite robust and can take some solid hits, however, the weak point in the suspension pin inserts . I've popped the back off of one and was still able to run the car. However, you need to pick up some more inserts for spares to adjust track width, arm sweep, and rear toe. So, pick up a few and you'll be good.
aracefan likes this.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 09-21-2016, 06:08 AM   #419
Cheers
Old 10-03-2016, 04:35 AM   #420
tlp
or
or
Hi sv,
How did you go with this set up for asphalt?
I would like to know how everyone is going with TBBS for asphalt.
Thanks.
tlp is offline   Reply With Quote
