VBC Racing D08
#346
#348
So I put the standard plastic rear upright on my car and set the droop at .5 as specified on one of the asphalt setups, then put the aluminum upright back on (not that it mattered) and measured the droop under the center of the arm facing out, it measured 3.8, all done on droop blocks. (This would be on the arm as if the lower curvey thing on the plastic upright where removed). Hope that helps you out. Obviously, if the setup sheet specifies more like a 1.0 you would be 4.3 on the arm and vice versa.
#349
Nope, not in the Dynamics.
#350
What is the D08's internal drive ratio for working out fdr?
#352
#353
#354
So the D08 has multiple adjustments via screws in the chassis. What have you guys found the difference in feel is, between the adjustments in the one piece suspension blocks compared to the motor mount? Does the motor mount allow for more chassis flex and the suspension mounts do what? The suspension ones seem very far out, so how much does influence chassis flex, or does it even do it? Opinions?? Thanks
#355
Paul
#356
Experiment with removing a different pair of screws at a time (the outer serews on the f/rear pin holders is what I remove in most set ups. I have found it to be a good fine tuning option. One of the biggest changes was the motor mount top plate brace, it freed up the rear of the car.
Paul
Paul
As far as the "motor mount top plate brace", do you mean the multiple configuration standoff posts? I have used them in combination with the 3 different top decks available and have found that going to the "gold" quasi top deck without the standoffs nets the best performance, although I think the "silver" is probably the better choice because of the track conditions at the moment and the chassis twist I'm looking for. These are all on the "gold" suspension pieces, which overall have made the car feel a lot more comfortable to drive. What I did find, and this was confirmed with another VBC driver as well as another brand driver, that the standoffs are good until you hit a board, then it creates a slight tweak in the car, which can only be reset by loosening and re-tightening those screws, not possible during a run though. This problem outways the usefulness the posts themselves so we try to avoid them and tune around it via the top deck thickness and flex characteristics.
Just looking for what others are finding with these adjustments. Any input is appreciated.
#357
Sounds to me like you're running on carpet if you are running the stiff gold parts... Im running in car parks with soda sprayed down for traction. I tun the silver plactic parts. I went too far on adjustments one day and made the rear end a little too loose, so I took out the FR outer screws and it hooked the car back up to where I wanted it.
#358
So I tried a combo of TBBS and solid mount on the front - I am impressed , much more composed and consistent , harder turn in and more corner speed
So , what next now ...
#359
