Like Tree8Likes
Old 07-23-2016, 06:22 AM   #331
EDWARD2003's Avatar
http://www.facebook.com/vbcracingusa...154985/?type=3
I noticed on VBC USA Facebook page that Yannic Prumper is doing quite well with the Wildfire D08 at the final ETS race.
I wonder what options he's running?
EDWARD2003 is offline   Reply With Quote
Old 07-23-2016, 09:43 AM   #332
Originally Posted by EDWARD2003 View Post
http://https://www.facebook.com/vbcr...154985/?type=3
The link doesn't seem to work Ed.
Rodney Racer is offline   Reply With Quote
Old 07-23-2016, 02:04 PM   #333
patorz31's Avatar
He is running a prototype according to redrc ets page.
"Running a prototype VBC this weekend which feature different material arms, Prumper said the car was ‘for sure a big step forward on the previous car’. With Carven Chow making the trip to Slovakia to support the Hong Kong manufacturer’s star driver, a change from a 3 to a 2.5mm swaybar for Q1 would give the car ‘a lot more steering’ with Prumper adding while making it ‘a little loose’ he was still ‘in control’ of it. By far Prumper’s most promising showing since his switch from Yokomo to VBC, his time 8/10ths of a second off old team-mate Volker, the former ETS race winner plans to ‘keep everything the same’ for Q2."
patorz31 is offline   Reply With Quote
Old 07-24-2016, 07:04 AM   #334
EDWARD2003's Avatar
I fixed the link. Sorry.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
Old 07-24-2016, 07:25 PM   #335
Trader Rating: 30 (97%+)
I have some brand new parts left for a d08, I have aluminum spring retainers all 4, aluminum battery holder with the Velcro strap, and some suspension ball nuts, asking 20usd, will be shipping from Canada. Pm for serious inquires.
zaraz is online now   Reply With Quote
Old 07-25-2016, 12:29 PM   #336
Pm sent zaraz. So here's a stupid question for you guys. I just bought a d08 and it's got aluminum rear hubs which don't have the brace running below the arm. Now my droop measurements are going to be more like a common car rather than the .5mm droop listed in other setup sheets...can anyone measure from the bottom of the rear hub brace to the bottom of the arm so I have a reference point? Thank you all, Peter
tudor39 is offline   Reply With Quote
Old 07-25-2016, 03:40 PM   #337
I do my droop setting as MM over ride height. Lifting the chassis and watching arm movement until tires just start to come off the setup board. This way its more consistant with runs tires and ride height changes.
freebird is offline   Reply With Quote
Old 07-25-2016, 09:36 PM   #338
I know that's the proper way but not how most do it and again doesn't give a reference point. Once I have reference point then I can go from there
Old 07-25-2016, 11:07 PM   #339
I'm at work at the moment and cant get to it till Weds, but I think the easiest way to get the measurement you want would be to measure the pin diameter and divide by 2, and then the total length from the top of the pin to the bottom of the cross brace. Then repeat with the aluminum rear up right, so you can figure the measurement difference. I can tell you that I prefer the aluminum uprights because as long as you don't have a really crazy camber setting the bottom of the upright makes for a very easy place to take your measurements from. If your looking for a ball park setting for droop on carpet, I would try 5.6 in the front and 4.6 in the rear (off the bottom of the rear upright).
Old 07-26-2016, 06:16 AM   #340
What type of track surface do you run on? Ive only run on carpet and have had my D08 on the new black CRC stuff which is major High traction. My frt droop is about 1mm-1.5 over rh and rr is right at 2mm over
Old 07-26-2016, 07:33 PM   #341
I'll be running it on asphalt. If I had a plastic hub I could measure this up pretty quick but I just don't have one. Thank you guys for responses
Old 07-27-2016, 06:41 AM   #342
Well D08 only came with the aluminum hub. I don't know if those running the car would change out to the plastic hub. So Im not seeing what your trying to do. A base line yes, I understand. But to compare to another chassis?
Old 07-27-2016, 12:23 PM   #343
Slotmachine's Avatar
Send a message via MSN to Slotmachine
My D08 has plastic hubs stock.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-27-2016, 03:01 PM   #344
I can measure from the pin hole to the bottom, most lowest point on both the plastic and the aluminum and give you those numbers.
Old 07-28-2016, 11:52 AM   #345
That was my understanding
