Like Tree9Likes
Old 07-14-2016, 06:27 AM   #316
Originally Posted by Slotmachine View Post
First day out with the D08 was good! After each change the car gained a 10th per lap. I qualified 3rd and finished 2nd in the A main. The flex system works great and is very effective at changing the car. I will make some serious changes the next time I run it. The Hobbywing power was awesome as usual.
Hi Slotmachine - would you be able to post a setup sheet for your D08? I'd be curious to see how similar our setups are. I am wrapping up the USVTA/USGT race season with my previous chassis but have done extensive testing with my D08 and the corner speed is incredible.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 07-14-2016, 09:59 AM   #317
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Here you go.....
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-14-2016, 12:51 PM   #318
Here you go.....
Thanks for the quick response!
Am I reading this correct in that you run 2MM of spacers under all the suspension mounts??
Old 07-14-2016, 02:50 PM   #319
I run the a arms with 2mm in front and 2mm behind (wheelbase) both end of tge car. 2mm on top of the rear hub 1mm in oard. In the front I run 2mm inboard, these are all the stock build settings for roll center.
Old 07-14-2016, 03:58 PM   #320
Yes but I'm pretty sure he is asking about 2mm under all the "suspension shim" settings on the setup sheet, just below the bar thickness setting on the sheet.
Rodney Racer is offline   Reply With Quote
Old 07-14-2016, 04:25 PM   #321
Sorry I misunderstood that is my wheelbase shims on the hingepin I didn't run any shims under the pin holders. I am going to try raising the whole rear with .5mm and the fr 1mm to remove some caster. Im also going to try sweeping the front arms forward to make the steering more aggressive.
Old 07-14-2016, 10:27 PM   #322
EDWARD2003's Avatar
D08 setup - Asphalt - high grip
I'll post my setup next week. My computer crashed so it's a tad difficult to load thing at the moment. This setup is using the TBBS shocks and LCG towers with SMJ springs.
Please hold on
I also suggest looking into getting the Xray PSS system for asphalt.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 07-15-2016, 10:09 AM   #323
No problem, thanks for the clarification.
Old 07-16-2016, 04:11 PM   #324
Okay I got to run the car after my changes and I got the steering I wanted. I put a 1mm shim under the FR pin mount and I put .5mm shims under all the rear pin mounts. I ended up going to 1mm shim in front of the rear arms and Im now running white rear springs and red fronts. I am still looking for the sweet spot on gearing and timing on the 21.5 motor
Old 07-21-2016, 01:14 AM   #325
TC5
The shock bodies are shorter as well.
Hi All ,
Any comments on the TBBS - is it an all round gain in terms of traction and corner speed - I mean in terms of low / mid and high traction ?
TC5 is offline   Reply With Quote
Old 07-21-2016, 06:59 AM   #326
Originally Posted by TC5 View Post
Hi All ,
Ive only run now for 2 races on the new black CRC carpet which is very high grip. as compared to the kit shocks on this carpet the shocks are more consistent because of less travel in the shock piston and able to let the shock do its work sooner. That translates to indoor real time reactions. Outdoor on pavement I have no experience with because there just isn't any tracks to run on in my area. My shock package I built to kit recommendations. Just changed fluid a little and shock position for my track. I did see a very positive and noticeable improvement.
freebird is offline   Reply With Quote
Old 07-22-2016, 11:09 AM   #327
Trader Rating: 16 (100%+)
Is there some where on here that has the spring rate for the TBB and the TBBS springs?
jtsbell is online now   Reply With Quote
Old 07-22-2016, 01:59 PM   #328
There is now.
Old 07-22-2016, 04:22 PM   #329
Thanks for the info Rodney.
Old 07-22-2016, 05:06 PM   #330
EDWARD2003's Avatar
If you're looking for the digital copy, check out VBC's Support page or simply click on the link below for the TBB Shock Information.
http://cdn.shopify.com/s/files/1/016...mation.pdf?683
