Like Tree8Likes
Old 04-27-2016, 12:49 AM   #256
Originally Posted by Loheswaran View Post
I appreciate your help there.
I am sure the 08 is better than the 07, but in my hands it'll make no difference.
I just wish that the VBC was better supported in the UK. The schumachers, Xrays, Tamiyas, and Yokomos always have trackside spares available, in fact you even get Awesomatix and ARC but the VBC hasn't any - a real shame
Mb models has taken over as the importer for vbc and I can get most bits for my d07 some for the d06 and loads for d08 if he hasn't got it he gets it in quite quickly
just a shame there isn't a uk team there is only one uk racer for vbc and it says he runs the ghost
tcboy1983 is offline   Reply With Quote
Old 04-27-2016, 03:24 AM   #257
Anyone know if the motor mount from the D07 fits right in to the D08 chassis
NettoRc Sweden
Team AE B6
MuchMore Racing
Advance Electronic's
hasse85 is offline   Reply With Quote
Old 04-27-2016, 04:15 AM   #258
Richards Racing's Avatar
No 07 screws in from spur gear side 08 screws in from motor side.
Noel
RC Core - Castlehill Raceway
O/M - VBC Racing - M05 - Sanwa - Hobbywing
Junior - ARC - Killshot - Spektrum DX3R Pro - Hobbywing
Daughter - VBC Racing - Spektrum DX3S - Hobbywing
Richards Racing is offline   Reply With Quote
Old 04-29-2016, 06:28 AM   #259
Default Wtb D07
Looking for a good D07 or D08. For good price
bigtee01 is offline   Reply With Quote
Old 04-29-2016, 05:02 PM   #260
tonyv2382's Avatar
Trader Rating: 64 (100%+)
Send a message via Yahoo to tonyv2382
Just purchased a D08. Hows everyone liking it thus far?
tonyv2382 is offline   Reply With Quote
Old 04-29-2016, 06:55 PM   #261
EDWARD2003's Avatar
Awesome chassis! Switched from the BD7 2016 and haven't regretted the switch. This car has a lot of corner speed and so easy to drive.
Build tips.
- use a 3 mm reamer on all areas using the hinge pins.
- drill a hole in the shock cap for zero rebound
- be careful when gluing the front spool pulley cage on.
- use rubber orings under the ball cups holding the roll bar mounts
(removes up and down slop)
-pre-tap any holes using a standard screw which require an aluminum suspension ball end. I broke one (thanks linkless for the correction)
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 04-29-2016, 09:09 PM   #262
Trader Rating: 38 (100%+)
Originally Posted by EDWARD2003 View Post
-pre-tap any screw holes using aluminum ball ends. I broke one
To clarify the above statement, use a standard screw to pretap any holes that an aluminum ball end will be threaded into
I've only got 3 race weekends on the car and my first thought is that the car has amazing cornering speed. I get to put some more time on it tomorrow and will be going to Reedy with it at the end of May.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 04-29-2016, 11:11 PM   #263
tonyv2382's Avatar
Thanks, for the clarification. Do You mean ball stud? Are they weak?
Old 04-30-2016, 12:15 AM   #264
angrymelon's Avatar
They're not weak, just made of aluminum and combined with the new plastics being super hard, they go in snug.
-=Ryan B=-
VBC Racing USA - Team Powers USA
PDX On-road: https://www.facebook.com/groups/onroadracing/
angrymelon is offline   Reply With Quote
Old 05-02-2016, 01:28 PM   #265
Is the DCJ pin, with a flat spot, 2x10mm or 2x12mm? In the manual is says it's 2x10mm but VBC racing shows it as 2x12mm.
malkiy is offline   Reply With Quote
Old 05-02-2016, 08:12 PM   #266
Burlap's Avatar
Send a message via MSN to Burlap
It's the 2x12mm
Burlap is offline   Reply With Quote
Old 05-04-2016, 03:57 AM   #267
tonyv2382's Avatar
Im sure someone has asked but does the D07 fan mount fit the D08? I dont think I saw the mount in the kit is it considered an option part?
Old 05-04-2016, 05:40 AM   #268
Les
Les's Avatar
Default Option
Yes Tony it is an option, not sure if 07 same as 08 someone will clarify this for you.
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 05-04-2016, 05:53 AM   #269
EDWARD2003's Avatar
Same option part number for the 07 and 08.
                 VBC 12M - D08 - FX
Old 05-04-2016, 02:50 PM   #270
tonyv2382's Avatar
Just got to the spur assembly. Whats the deal with all the side play? Ive added shims but it still feels loose.
