Like Tree8Likes
Old 04-04-2016, 10:57 PM   #226
EDWARD2003's Avatar
Awesome, I am looking forward to seeing your setup.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 04-05-2016, 05:58 AM   #227
I've been working with testing and tuning my D08 lately and believe I have it dialed in pretty well. Made a few changes from the kit set up to suit our track and I have to say that it is awesome.
This car is VERY smooth and quite. Probably one of the quietest cars on the track. Grip is crazy (running USGT spec tires on "old" carpet) and response of the car is very controlled yet responsive.
TQ'd but had the main cut short due to a head on hit with a lapper that was trying to get turned around and going the right direction. The front bumper got torn and rolled under the car giving it a great bounce going down the next straight!
All in all, the car is very good and I'm incredibly happy with it.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 04-05-2016, 06:39 AM   #228
Where do you run? and what changes have you done from the kit.
Looking to see what some have done to setups on the carbon chassis for carpet racing in the States.
freebird is offline   Reply With Quote
Old 04-05-2016, 02:36 PM   #229
Looking for some info from those that have used the different shock bladders in shock tuning. If you've changed nothing else with the shock; ie. fluid, piston or spring; what will the different blades do for you in helping you tune.
Old 04-06-2016, 02:48 PM   #230
Akhor's Avatar
Originally Posted by Johnny Wishbone View Post
Thanks for the info on this. I did this last night and it adds a lot of strength to the inserts! Doubt I'll ever pop another one.
--Blaine--
VBC D07, VBC D08
Mugen MBX 7, Mugen MBX 7 Eco,Mugen MBX 7r, Mugen MBX 7r Eco
www.rcgears.net, www.carcar.ca, www.karz.ca
Akhor is offline   Reply With Quote
Old 04-10-2016, 10:35 AM   #231
Does anyone know if the D08 hinge pin holders will work on a D07? I like the idea of being able to adjust this with "pills" instead of buying more rear and front holders.
Thanks,
Jon
Juniorabca is offline   Reply With Quote
Old 04-10-2016, 04:22 PM   #232
Thanks,
Jon
They may fit if you ground off the lug that it has which locks it in place on the DO8 chassis. Im also unsure if the screw holes are in the same place.
69rotang is offline   Reply With Quote
Old 04-10-2016, 05:39 PM   #233
EDWARD2003's Avatar
Watched Yannic first run with the VBC D08 on RedRC. He did quite well considering it was his first time out with the new chassis.
                 VBC 12M - D08 - FX
Old 04-10-2016, 07:09 PM   #234
Benzaah's Avatar
Trader Rating: 21 (96%+)
As mentioned grind of the lugs and you'll be fine. A few guys have gone back to the 07 holders on the 08 due to the weak pill issue we e been suffering with.
This weekend gone we had the Australian Victorian state titles. This is the next state over and we arrived Thursday morning to an unprepared track. Spent all Thursday learning the track to then have the grip go through the roof once it was sugared. I started from scratch again on Friday practice and didn't really find a great set up. Went into qualifying not really confident but hopeful to pull of a few good rounds. Learning the new track was the hardest part and there were lots of fast locals out to prove a point. My 40 year old eyes and reflexes aren't what they used to be!
I ran 13.5 Blinky in a 34 car feild finishing 12th overall. My best rounds were a 6 and 7 but I had a 12th which gave me the dreaded BQ. The car was quick but inconsistent with the varying track temps. I had some great battles. I'll post a set up when I can be bothered looking at the car again.
We tested a lot of stuff and changed the flex settings in the blocks, motor mount and steering posts through the event. Will be interesting to see how the car handles at the next club meet with the new set up.
Great drive by FredP's son to win the B group. The kids going to be one to watch as he's got a lot of talent.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is online now   Reply With Quote
Old 04-14-2016, 08:21 PM   #235
Fredp1's Avatar
Hi Ben,
Thanks for the complement to Dean. He enjoyed the battle with you at the front of the B's.
I realised the rear shocks were mounted in holes 3 and 4 on the shock tower for the first 4 qualifiers. Once corrected for the last qualifier and finals, he was able to drive the car to its full potential
Hope to catch up with you again soon.
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 04-15-2016, 12:17 AM   #236
EDWARD2003's Avatar
I'll let you in on a little issue I had when setting proper ride height and balancing my D08.
While setting up the ride height I couldn't figure out why the Rear left and right were off by 0.6 mm and 0.2 mm left to right with the front. I double checked to make sure the left and right static balance which was perfect. However, the issue wasn't going away. I was scratching my head as to why this was still happening. In hopes of finding the problem I went ahead and checked the shock and suspension. All the shock lengths, spring lengths, droop screws were all exact.
Then after putting it all back together it still had the same problem. So I started to dig deeper and removed the shocks and looked at the suspension arms, hubs in more detail. I did some tests and moved the suspension through it's full range and the right side upper camber link made contact with the body post. I thought this was strange, because the left upper camber link was well clear of the body post. I thought the outer hub was on the wrong side. Nope. Everything was fine. Then, then, the very last thing I looked at was the suspension pin holders. I somehow placed the right ride holder in the wrong way so the left side was 5 dots facing out whereas the right was 5 dots facing in...felt like an idiot.
Once I fixed this, everything was spot on.
                 VBC 12M - D08 - FX
Old 04-15-2016, 05:14 PM   #237
Professor's Avatar
Attention to detail 👍👍
VBC RACING AUS--HOBBYWING--MAD GRAPHICS--BITTY DESIGN
Professor is offline   Reply With Quote
Old 04-15-2016, 05:31 PM   #238
Les
Les's Avatar
I think it's great we have a real human here, sharing a story where he made a little mistake, then worked out where he went wrong and sharing it with us 👍
Les is offline   Reply With Quote
Old 04-15-2016, 10:23 PM   #239
Professor's Avatar
Les. I wasn't having a go at Edward merely pointing out that you have to pay attention when working/building rc items
Old 04-16-2016, 04:31 AM   #240
Wtb D07 or D08
bigtee01 is offline   Reply With Quote
