Like Tree8Likes
Old 03-26-2016, 06:48 AM   #211
EDWARD2003's Avatar
Picked a D08 and wondering what's a decent setup for carpet?
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 03-26-2016, 06:56 PM   #212
Really interested in these cars. Anyone have a good cond used one they want to sell?
GimpyGolden is offline   Reply With Quote
Old 03-27-2016, 10:57 AM   #213
eevul's Avatar
For 17.5, you can try John Tsang's setup that's posted on Petit RC.
http://site.petitrc.com/reglages/vbc...acing20160118/
eevul is offline   Reply With Quote
Old 03-28-2016, 08:28 PM   #214
Default Suspension insert fix
Originally Posted by zoomster View Post
Hi at present i have not heard of a fix for it.
As im a mod driver i normally don't play around with track width on the rear only toeing,so Ive gone back to solid blocks,as at present its the rear inserts i was having the problems with breaking through.
The front Ive left with the inserted suspension blocks.
Here is my fix for the blown out suspension inserts. I cut small very thin brass shim stock to fit in the suspension holders. I held the shim in place with a old wrecked suspension insert, then I used my soldering iron and built up the area as shown with silver solder. Its about 1.5 to 2mm thick but gives it a good backer to prevent the pin and ball from punching thew the plastic insert.
Rodney Racer is offline   Reply With Quote
Old 03-29-2016, 03:03 AM   #215
zoomster's Avatar
Hi Rodney,il give it a go.
Team Bust Out The Shorts Racing
zoomster is offline   Reply With Quote
Old 03-29-2016, 09:01 AM   #216
Johnny Wishbone's Avatar
Default Bridge mod
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 03-30-2016, 09:17 AM   #217
I also encountered the inserts breaking out. I had 4 break over the first 2 weeks of testing the car. I found than my hinge pins were longer than what is allowed by the inserts so there is constant pressure on the inside of the inserts from the pins.
I shortened my hinge pins by 1MM and have not broken out any inserts since the mod.
Rodney Racer - VERY nice mod with the silver solder. Looks super clean and should hold up no matter what.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 03-30-2016, 10:33 AM   #218
Budman's Avatar
Trader Rating: 22 (100%+)
My D07 and D08 ready to go!!!
Cooper Motorsports, Team Trinity, T-Rex Racing, GFRP, MSA, VBC Racing, Track Attack, Tekin and Frost-bite Graphics
Budman is offline   Reply With Quote
Old 03-30-2016, 05:56 PM   #219
EDWARD2003's Avatar
Nice idea, I would go one step further and cut a thin piece of rubber (o-ring) and place it between the pin and plastic housing. I wonder how much material I can cut off the pin before I start running the risk of it popping out?
Cheers.
Any shock build tips?
I am going to start building mine up tonight and do videos along the way.
All the best,
Edward.
                 VBC 12M - D08 - FX
Old 03-31-2016, 07:35 AM   #220
Wink
why do you have a 17.5 in the GT? Cheater!!!!!!!!!!
freebird is offline   Reply With Quote
Old 03-31-2016, 07:53 AM   #221
^^^ Good catch lol!
Old 03-31-2016, 11:45 PM   #222
Budman's Avatar
Lol, I didn't have a 21.5 ring to go on the motor. But it's changed now. Lol I didn't think anything about it until after I had taken the picture.
Old 04-03-2016, 06:56 AM   #223
EDWARD2003's Avatar
Originally Posted by E-clip View Post
Has anyone else had a problem with the top deck rubbing on the layshaft front pulley? Is there a fix for this?
I had this exact same issue. I flipped over the upper deck and now it's fine.It seems as if there is only way to mount the top deck.
VBC could simply countersink the screw hole for the belt tensioner and this would show which way the deck should be mounted.
                 VBC 12M - D08 - FX
Old 04-03-2016, 08:07 PM   #224
EDWARD2003's Avatar
Did a little video on the D08.
https://www.youtube.com/watch?v=N2trNfydVog
I will do a shock build on a later date.
                 VBC 12M - D08 - FX
Old 04-04-2016, 01:12 PM   #225
Trader Rating: 38 (100%+)
I was able to get a second race weekend on mine and with the proper tires ended up with the fastest car on the track. Traffic difficulties took me out of TQ contention and a driver that didn't want to be passed managed to hit me in the next section after each of 3 clean passes I put on him. I did get into him a time or two early in the race so I'm not worried but the fact I was able to easily close the gap all but the last time left me feeling very confident on my run up to Reedy. I did have the fastest lap and fastest averages across the sheet for the main event.
I will get a full setup posted here later this week, but there is nothing exotic about it as it's using all kit parts. The Sweep 36EVO-R tires were awesome as is the STC-4 body.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
