Like Tree8Likes
Old 03-11-2016, 09:56 PM   #196
midse's Avatar
Default Track
Originally Posted by Yokolun View Post
check the front bearing?
Check servo mounting screws and all screws for that matter. Also arm suspension pin slop
midse is offline   Reply With Quote
Old 03-12-2016, 02:34 AM   #197
Turns out it was the rear left suspension arm pin, it had a considerable bend in it, straightened it out, checked and adjusted all turnbuckle lengths, it is now pulling much straighter
Lowie57 is offline   Reply With Quote
Old 03-12-2016, 03:01 AM   #198
EDWARD2003's Avatar
Buy new ones.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 03-12-2016, 12:33 PM   #199
Originally Posted by EDWARD2003 View Post
Buy new ones.
+1 if your in a pinch sure but definetly replace it the first chance you get.
On another note I just ordered all the new goodies. Aluminum chassis, short shocks/springs/shock towers.
Stoked
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 03-12-2016, 02:42 PM   #200
Benzaah's Avatar
Trader Rating: 21 (96%+)
Is anyone having issues with the arm pin inserts breaking? I'm finding that after a tumble or a wall hit the pins are busting through the thin edge. No other part is being affected so it's kinda a cheap fix but it would be much better in a delrin plastic not this flimsy black plastic.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 03-12-2016, 03:20 PM   #201
zoomster's Avatar
Yep,its the ball that is causing the punching through,if anything they should of only left a 2 mm hole to push the insert out,not machine the suspension block down at the back,its not leaving any support for the insert.
Team Bust Out The Shorts Racing
zoomster is offline   Reply With Quote
Old 03-12-2016, 07:06 PM   #202
Svendc's Avatar
I prefer inserts instead of alu fixed blocks, but more solid ones like the TC7 or the team magic ones. So good point to work on.
Svendc is offline   Reply With Quote
Old 03-22-2016, 06:07 AM   #203
The One They Call Dirty's Avatar
Trader Rating: 57 (100%+)
Got my car today, can't wait to start the build!
92zero Designs -Diggity Designs
Fantom Racing - Lunsford
MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 03-22-2016, 08:50 AM   #204
I had a nasty wreck with mine when a pin in the front left CVD broke and sent me nearly head on into a wall. Snapped the top deck amongst other things. Just received the top deck from VBC (as VBC USA does not yet carry it).
Took the time to make a few of the shock mods that have been suggested and clean up my wiring.
Looking forward to getting it out this weekend for some testing and tuning. This is still not my primary chassis but with additional testing I think it could easily be just as good. Excellent craftsmanship on the kit.
Awesomatix A800 x2, VBC D08 / D07, CRC WTF16 F1
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 03-22-2016, 09:31 AM   #205
Trader Rating: 38 (100%+)
I raced mine in 17.5 on asphalt for the first time last weekend and can say I was very happy with it. Tire choice later in the day took me out of contention but to run lap for lap with some of the fastest guys in AZ during the first heat with it left me with a lot of confidence.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 03-22-2016, 11:47 AM   #206
tbrymer's Avatar
Your car looked good and when I drove it, it felt awesome!
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 03-24-2016, 09:46 AM   #207
Anyone come up with a fix for this yet?
Rodney Racer is offline   Reply With Quote
Old 03-24-2016, 01:02 PM   #208
zoomster's Avatar
Hi at present i have not heard of a fix for it.
As im a mod driver i normally don't play around with track width on the rear only toeing,so Ive gone back to solid blocks,as at present its the rear inserts i was having the problems with breaking through.
The front Ive left with the inserted suspension blocks.
Old 03-24-2016, 04:25 PM   #209
Anyone know of hand the min/max size pinion you can fit with the stock 116 tooth spur?
GimpyGolden is offline   Reply With Quote
Old 03-24-2016, 10:09 PM   #210
Anyone has experience with the new short shocks and lower shock towers?
Ted Su(TW) is offline   Reply With Quote
