Like Tree8Likes
Old 05-13-2016, 08:29 AM   #61
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Running the +3 exotec rims on the back of the car....and proper shims with standard offset fronts opens up a decent tuning window as well.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 05-18-2016, 05:13 PM   #62
Csaari77's Avatar
Trader Rating: 34 (100%+)
I'm in the market for a new car and I'm really interested in this car. How is the durability? Has it been responsive to adjustments? How is the front end, very responsive or numb like the Tamiyas?
Csaari77 is offline   Reply With Quote
Old 05-19-2016, 03:15 AM   #63
corally's Avatar
Originally Posted by ralph m View Post
Have you guys cut the shock shaft to achieve the specified length in the manual? I can't get there unless I do.
Have placed the shim on (internally...)shaft ?
corally is offline   Reply With Quote
Old 05-19-2016, 05:54 AM   #64
Hello,
It's really a good car! Easy to work on and you don"t need options(like Xray).
Pretty easy and fast out of the box.
You can find my setup for outdoor there : http://site.petitrc.com/reglages/roc...se_Genk201605/
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 05-19-2016, 06:02 AM   #65
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
Yes, 1mm under the piston.
tqwire.com
ralph m is offline   Reply With Quote
Old 05-19-2016, 06:26 AM   #66
on the manual, I read that the shim under the piston must be 2 mm. (#S10032)
Mafodda is offline   Reply With Quote
Old 05-19-2016, 09:51 AM   #67
ralph m's Avatar
Using 1mm gave me the uptravel I wanted.
tqwire.com
Old 05-22-2016, 07:23 PM   #68
j.d.roost's Avatar
Had a great day of practice with the car today. It was fast and consistent all day.Lots of stuff tested (crc old carpet) and I made a few tweaks to my setup.
A.E. #18 springs are now my "go to" front spring and I went from 30k in the tubes to 20k. Also on our new tighter layout -1.5 (was at -.5) front toe seemed to help with turn in. Able to run unglued crc front tires now.It's got a truckload of steering...but still drivable.
Lot's of comments on how my car looks "flat".
I would love to have a 0/1 camber plate...if any of our gang has the ability to produce such a piece.
Fantastic car.
F1
Roche usa
R.I.P. Jon Williams
Old 05-24-2016, 05:54 AM   #69
corally's Avatar
Default camber issue
Hello
if some one found a different camber angle between side i suggest to check the stand off....on my kit two have teh face not parallel...but place on rear post of lower brace all is ok now...grat car
Old 05-24-2016, 07:31 AM   #70
j.d.roost's Avatar
Hello
Yes..the kit red standoffs can bend if you tap.
I had this happen.
The McMaster parts are more durable for sure.
I think Roche is going to address these parts anyway due to the ride height limitations (there was a Facebook post regarding this).
F1
Roche usa
R.I.P. Jon Williams
Old 05-24-2016, 08:11 AM   #71
corally's Avatar
Hi
not bended..i spoke for untouch parts... think the milling process not controlled or quality check not accurate
Old 05-25-2016, 05:17 PM   #72
nogarats's Avatar
Do you have the link for the McMaster parts?
Awesomatic 800X, F1 Roche EVO
Nog.
nogarats is offline   Reply With Quote
Old 05-25-2016, 08:51 PM   #73
hanulec's Avatar
Trader Rating: 27 (100%+)
Nog-- depending upon where u got your kit -- it would have been included. Just sayin'
Its a 12mm standoff for 3mm screws. Roche also just released a 11.8mm red alloy standoff.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-26-2016, 03:42 AM   #74
nogarats's Avatar
Ok Thanks
Nog.
Old 05-27-2016, 01:17 PM   #75
GasGod's Avatar
Hi JD-long time -no see-It's me jeff-from T&L-horsham f103 day's. Is this kit as good as I hear?lookin ta get a new style F1.The new [email protected] T&L is great. Where ya runing at?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
