Like Tree8Likes
Old 04-24-2016, 03:39 PM   #46
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Got my car dialed in for the rug (just in time for outdoor season...).
Past few weekends have resulted in Tq and wins at my local (and points series p1).I felt very "locked in" today with my new setup. (old crc carpet). Thanks for posting your setup guys.
My setup.
30k in the tubes, thin grease on the pins,tamiya gold front springs (or a.e. #18 depending on grip), 1.5 camber and 9 caster,stock side springs,500 cst oil in the shock,xray 2.7 main spring,stock front shims with the shorter ride height standoff (McMaster parts I think).
1mm rear pod droop. x1 2016 body
Car is great...driver needs to stop tapping. I am a lot harder on the car then you "fast guys"...everything seems to be holding up well so far.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 05-06-2016, 08:27 AM   #47
Is the manual posted somewhere online?
[RC10TC] is offline   Reply With Quote
Old 05-06-2016, 09:40 AM   #48
hanulec's Avatar
Trader Rating: 27 (100%+)
http://www.rochercusa.com/p/downloads.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-12-2016, 12:47 AM   #49
spencehotbodies's Avatar
Default Can't wait to run this
Looking forward to running this.
spencehotbodies is offline   Reply With Quote
Old 05-12-2016, 03:40 AM   #50
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
My setup.
Did you lower the upper a-arms as well?
I put 2mm shorter lower standoffs in and then lowered the upper A-Arms 4mm and lowered the bell crank 2mm.
It changed the roll center and increased corner speed on the new CRC carpet.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 05-12-2016, 06:54 AM   #51
j.d.roost's Avatar
How did you lower the upper arms?
Did you mill the servo holder?
Also wanted to add I only switched from the stock front spring because I lost one. The tamiya gold seemed closest to the same rate.
F1
Roche usa
R.I.P. Jon Williams
Old 05-12-2016, 07:43 AM   #52
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
I was thinking about this too... My guess is that he lowered the upper arm at the steering block by removing the shims above, making it "flatter".
Wayne?
tqwire.com
ralph m is offline   Reply With Quote
Old 05-12-2016, 07:44 AM   #53
ralph m's Avatar
Is it necessary to use a shorter standoff to increase ground clearance?
tqwire.com
Old 05-12-2016, 08:33 AM   #54
corally's Avatar
SG1...to lower the upper arm is necessary milling the servo mount not only place a lower standoff...right?
corally is offline   Reply With Quote
Old 05-12-2016, 08:54 AM   #55
hanulec's Avatar
Yes... Wayne is a mad scientist
With the exception of 4 lower standoffs I'm just playing with shims, camber, springs, etc
Old 05-12-2016, 10:13 AM   #56
j.d.roost's Avatar
If you still want droop at 4mm ride height yes.
F1
Roche usa
R.I.P. Jon Williams
Old 05-12-2016, 04:31 PM   #57
sg1
sg1's Avatar
I did mill the servo holder down (just where the top plate mounts).
I found a standoff McMaster had to replace the long one going to the upper a-arm plate that was about 4mm shorter then the stock one.
I used Assoc. .018" 1/12 springs and have about 3.5mm droop now with 4.5mm ground clearance.
With CRC .45mm side springs and 10K in the tubes I get alot of chassis roll and great corner speed. Here's the layout I ran on:
Old 05-13-2016, 06:46 AM   #58
corally's Avatar
Thanks Sg1..
you run on carpet... i run only to asphalt medium grip...not sure same result..
Old 05-13-2016, 06:57 AM   #59
ralph m's Avatar
Have you guys cut the shock shaft to achieve the specified length in the manual? I can't get there unless I do.
tqwire.com
Old 05-13-2016, 06:59 AM   #60
sg1
sg1's Avatar
Thanks Sg1..
I think it should help, I gained steering and overall corner speed with those changes
One thing you could also try is rear track width, it's pretty narrow out of the box.
