Like Tree8Likes
Old 05-04-2017, 06:26 AM   #256
Originally Posted by robk View Post
I dont have a roche car but i will back up Brent. These are not foam tire cars. You have to think about changes you would not make on a foam tire car.
I have made similar changes on Tamiya, Speed Passion, Crc, and it works to free up the car.
Rob are you referring to the side link shimming or the stiffer spring?
freebird is offline   Reply With Quote
Old 05-04-2017, 07:47 AM   #257
robk's Avatar
Trader Rating: 22 (100%+)
Shim the side link.
freebird likes this.
Old 05-04-2017, 10:17 AM   #258
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Any idea when the following parts might be back in stock?
Aluminum Chassis
Aluminum Lower Pod Plate
Rear Wing Mount
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 05-04-2017, 12:46 PM   #259
Csaari77's Avatar
Trader Rating: 34 (100%+)
Where and how are you mounting motor fans on the car?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 05-04-2017, 11:42 PM   #260
Kevin CBR's Avatar
I saw a lot of guys at the MHIC race at 5280 Raceway in Denver mount the fan on top of the motor with a mount that goes around the motor can. If you run a thin fan like the WTF fan, you can also mount to the left pod mount. There are threaded holes near the bottom of the mount.
Panda
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 05-05-2017, 07:19 AM   #261
Csaari77's Avatar
What size fans are people mounting on the left pod? 25mm or 30mm?
Old 05-05-2017, 08:53 AM   #262
bkspeedo's Avatar
The R1 Wurks fan mount and WFT fan are perfect for F1. You do have to cut the rear of the body up further but not a big deal.
The problem with mounting the fan in the left bulkhead blowing on the timing ring side of the motor is, it does not cool the motor enough. Everyone that uses the over the top approach sees a 15 to 20 deg drop in motor temp over side mounting.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-05-2017, 03:43 PM   #263
Csaari77's Avatar
Thank you. Do you have any idea where I can find one of the R1 mounts? Everywhere I've looked is out of stock.
Also, where can I get a set of battery mounts for the inline setup? I can't find them on the Roche or Roche USA site.
Old 05-22-2017, 07:00 AM   #264
Csaari77's Avatar
I finally got my car on the track yesterday. Besides knocking 3 years of rust off my driving the car was pretty good, and got better with every change I made. I did have an issue with the pivot ball bushings popping out of the arms. I was getting really annoying. Does anyone have a solutions for keeping them in the arms? Should I just use a spot of CA, or is there a better solution using the o-ring?
Old 05-22-2017, 07:11 AM   #265
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
I CA the bottom ones and use the o-ring. Make sure the bushing on the bottom arm has the o-ring on top, the picture in the manual can be confusing.
Also, X-Ray bushing are compatible and seem to have a bit more "snap" when the suspension ball is inserted.
tqwire.com
ralph m is offline   Reply With Quote
Old 05-22-2017, 07:22 AM   #266
Csaari77's Avatar
Will the Xray pivot balls also work?
Old 05-22-2017, 07:30 AM   #267
ralph m's Avatar
never tried them
tqwire.com
Old 05-22-2017, 08:21 AM   #268
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
My latest set up
I added weight to the front end to get 220g+ per front tire and things went really well on a very technical layout.
Car stayed flat, no diffing, great stearing.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
Old 05-27-2017, 08:28 PM   #269
After months not playing with the F1, I rebuild most of it yesterday and hit the track.
I used a similar setup to Alex Stocker's from the last round of ETS (On Arno's site) except used Xray 2.5 center spring, 30k in the side tubes and xray c1.2 side springs on Xray's spring holder, ride soft front springs.
Car was pretty nice to drive - only thing I think would be the oversteer mid-corner if I yanked the car into the corner. Maybe stiffer side springs needed? Any thoughts?
Also has anyone had a look at the bump steer in the steering? The steering arms on my car seem REALLY angled - just wondered if anyone's tried taking this out?
Cheers!
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 05-30-2017, 04:07 PM   #270
Dapmc3's Avatar
Trader Rating: 47 (100%+)
Send a message via Yahoo to Dapmc3
Probably been mention but are people bending the chassis a lot? why are so hard to find if not? ourchased from a good guy but main and rear chassis was really twisted.
Dapmc3 is offline   Reply With Quote
