Like Tree5Likes
Old 03-05-2017, 11:34 AM   #211
I'm surprised, with Yok tyres which are Pit copies, I've 5,5 at the rear without shims. The issue, for me, was at the front, I had to get shorter Xray standoff to be at 5 mm as the rules in France said for indoor.
Gurneyflap is offline   Reply With Quote
Old 03-05-2017, 12:23 PM   #212
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Kevin CBR View Post
Just built a Rapide F1-2016 for a friend. Rear axle adjusters are on the low setting and with Pit Shimizu 575 rear tires, the rear ride height is at 4.2mm measured at the back of the pod. What do you have to do to get it up to 5mm to run outdoor or even on black carpet ?
Panda
possibly you have the RH adjuster/axle holder upside down?
i haven't run my F1-2016 since mile high... i cannot remember
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-05-2017, 12:38 PM   #213
Kevin CBR's Avatar
Flipped them both ways. Ride height is either 3.0mm or 4.2mm. We were running the Shimizu 572 or CRC equivalent at Mile High last year. Just bolted a set of Shimizu 572 rears on and raises to 4.6mm rear but does not help for when it will be run outdoor on the softer rear tire.
Panda
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 03-05-2017, 03:27 PM   #214
hanulec's Avatar
Panda
well another option would be to mount up the P10 motor plates and left plate. This will lower your axle and raise your ride height...
Old 03-05-2017, 04:15 PM   #215
Kevin CBR's Avatar
Just need the left and right aluminum mounts, no other pieces ? All other stock parts will bolt up with no modifying ? If yes, can you confirm part numbers for the two pieces. Worth trying. Thank you.
Panda 🐼
Old 03-05-2017, 05:08 PM   #216
hanulec's Avatar
Panda 🐼
it will bolt up. as would the P12 2015/2016 pod plates. the major difference is height of axles. 1/12 is the lowest. p10 is the middle. f1 is the highest. folks who wanna convert a p10 to rubber tires / wgt-r just use the f1 bulkheads.
Rapide P10 Aluminium Left Bulkhead
Rapide P10 Aluminium Right Bulkhead
Old 03-05-2017, 07:44 PM   #217
Kevin CBR's Avatar
Thanks Mike, I will give the P10 mounts a try.
Panda 🐼
Old 03-11-2017, 07:44 AM   #218
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Selling my side piece f1.
Car is so good I don't need an extra one.
Not sure on link rules so follow my postings or pm me.
175.00 shipped conti. Usa
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is offline   Reply With Quote
Old 03-14-2017, 09:16 AM   #219
Trader Rating: 37 (100%+)
On Kyle's Stock Wars setup...
No shims on top of kingpin so more droop? Anyone still using this or more standard 2 shims?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 03-14-2017, 03:20 PM   #220
Dobbs's Avatar
Trader Rating: 25 (100%+)
I run 2 shims on top, 2mm spacer above knuckle with 1 shim, and 1 shim below knuckle, and 1 shim above spring under lower arm. Gives me 1mm droop in front
Founder/Driver/Co-pilot/Crew chief/Pit crew/CEO/CFO/VP/Executive assistant/Head of secret santa committee:
Punk-Ass Racing
https://www.facebook.com/punkassracing/
Dobbs is offline   Reply With Quote
Old 03-16-2017, 06:33 PM   #221
Hows the easiest way to get my ride height in front of car. The back end is 4.5 but the front is 3ml
P.I.R.C is offline   Reply With Quote
Old 03-16-2017, 07:03 PM   #222
hanulec's Avatar
you need a lowered front standoff-
Rapide F1-2016 Aluminum Standoff Set, Short
Old 03-16-2017, 07:57 PM   #223
Yeah ive got the 12.8ml standoffs
Old 03-16-2017, 09:12 PM   #224
Kevin CBR's Avatar
Panda 🐼
P10 mounts did not work on the F1. Screw holes in the F1 are farther apart than the P10. However.... I changed to the aluminum rear pod plate (2.0mm vs. 2.5mm carbon) and that got me up to a 5.0mm rear ride height. Very happy with the car. With only one day of tuning and changing something every run including from Q2 to the main, was able to work up from 8th to 4th and just off the tail of the podium spot. Will have a good outdoor set-up with one more day practice on it. Going to change over to carpet set-up now and look forward to running the Roche at the MHIC race at Mile High in April for her first F1 carpet race.
Panda
Old 03-17-2017, 01:31 PM   #225
bkspeedo's Avatar
Panda
Kevin or anyone else. Have you tried raising the rear pod roll center? This is done by placing shims between the chassis and pivot ball assembly on the 2 crews that hold it into place and remove the appropriate shims from the front link mount point. What I'm currently doing and everyone at 5280 that owns a Roche F1 now has done this and seen an improvement. Remove the 1 mm shims from the front link mount point and place them under the rear pivot ball assembly. Effectively raising the rear pod 1mm. Makes the car rotate better from the rear. When the grip is high I also only dope the center of the rear tire. About the width of the SXT dauber which is about 60-70% of the tire.
This car has been very dominate at 5280 since Kyle and I started running it here.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
