Like Tree8Likes
Old 02-06-2017, 04:18 PM   #196
bkspeedo's Avatar
Originally Posted by Nexus View Post
How are everyone's Roche F1 running...
Looking for more offpower turn in..
6* caster
2* camber
4.5mm ride height
Tamiya silver front springs
AE silver rear side springs
Stock.shock spring
Sideways pack
Was debating going back to Kyle's setup and try 9-12 caster with lower camber.
black CRC carpet...11 sec lap time down to 10.4 for fastest guy.
As mentioned you could add more rear droop. Some toe-out up front. Reduce Ackermann (move bell crank forward), I liked this at 5280. May not have been good at Snowbirds with the greasy grip though. Mark Burt was the fastest with a Roche F1. He qualified 4th. When i looked at his car it was rather conventional, meaning like most other F1 setups.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-07-2017, 10:25 AM   #197
Trader Rating: 37 (100%+)
Going to recheck my droop and go over car tomorrow to test based on some of the recommendations.
Thank all!
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 02-25-2017, 06:52 PM   #198
Grumpybrat's Avatar
Trader Rating: 17 (100%+)
Need some help, no matter which way I turn. It diffs out. Any ideas
of what to do?
Grumpybrat is offline   Reply With Quote
Old 02-25-2017, 07:25 PM   #199
hanulec's Avatar
Trader Rating: 27 (100%+)
of what to do?
More side spring pressure
Talk to Brent
Make sure the front end and pod isn't bound up...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-26-2017, 05:31 AM   #200
j.d.roost's Avatar
Trader Rating: 28 (100%+)
This looked like a cool idea.
I get some chassis sag...and a keen yokomo driver came up with this. Testing today.
F1
Roche usa
R.I.P. Jon Williams
j.d.roost is online now   Reply With Quote
Old 02-26-2017, 06:01 AM   #201
Grumpybrat's Avatar
Thank you sir and I will.
Old 02-26-2017, 05:57 PM   #202
Originally Posted by bkspeedo View Post
I need to add a few more things to the pivot ball assembly sticking issue.
Slide a M3 wrench shaft through the pivot ball of the bushing and pivot ball assembly (you could use the king pin as well it's just easier with a wrench). Using a pair of pliers or something else you prefer. Hold the pivot ball bushing by the part that fits into the carbon arm. Squeeze with a fair amount of pressure and move the pivot ball around with the M3 wrench. Move the pliers to a new location of the pivot ball bushing. Repeat this until you've gone all the way around the pivot ball bushing, about 5 different locations.
I bought a used rapide and ran it for the first time. It was easy and fast, with a little understeer. Anyway, the pivot balls do not move freely, so I want to try the above procedure. But I can't get those bushings/pivot balls out. Before I break one, is there any trick to remove them without destroying them? Thanks. Otherwise I love this kit!!
Larryscooterman is offline   Reply With Quote
Old 02-26-2017, 06:30 PM   #203
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
Default F1
Hello
I brought a used F1 2016...and it is a cool looking F1...This is my first time race the car last night on Grey Carpet and I TQ and won..not bad..
next two week ,I will be runing the P12 2016....cant wait...
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-27-2017, 01:54 AM   #204
Our car still very competitive here in Europe!
We put 2 cars in top10 @ETS!
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 02-27-2017, 02:10 PM   #205
Can somebody please tell me the internal ration of the F1 Roche
DavidNERODease likes this.
P.I.R.C is offline   Reply With Quote
Old 02-27-2017, 03:29 PM   #206
JayL's Avatar
1:1
spur/pinion=FDR
MOD: A800X R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche EVO R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 02-28-2017, 02:26 PM   #207
Also deos there need to be an o ring but in the dampening bats that attach t the motor mount the shock oil seems to leak out. I'm a newby to f1
Old 02-28-2017, 03:39 PM   #208
sbd
Yes. O+riengs all the awau! My motor leask too.
sbd is offline   Reply With Quote
Old 02-28-2017, 08:09 PM   #209
Sorry shithouse typing. Any idea what size orings are needed
Old 03-05-2017, 11:13 AM   #210
Kevin CBR's Avatar
Just built a Rapide F1-2016 for a friend. Rear axle adjusters are on the low setting and with Pit Shimizu 575 rear tires, the rear ride height is at 4.2mm measured at the back of the pod. What do you have to do to get it up to 5mm to run outdoor or even on black carpet ?
Panda
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
