Like Tree14Likes
Old 05-31-2017, 01:06 AM   #466
Yesterday evening the first race. I didn’t yet have the softer springs I ordered nor the anti-roll bar in the front, so the car was still heavily oversteered under power. But, I still had a blast slipping and sliding about and managed 8th out of 11. Can you imagine how bad the other three guys drove…
There is certainly room for improvement in the grip / handling area. The springs and anti-roll bar as mentioned, but I have found two other issues. One is the ball joints at the lower end of the dampers are way too tight. The rest of all ball joints were fairly tight during the build but have loosened up a bit, so they are OK. But these specific ones are still way too tight and hinder fluent motion. I tried to squeeze them with a pair of pliers to loosen them, but that didn’t work. Is there an upgrade ball joint? I like the Tamiya Fluo coated ones, but those are 5mm and I believe the BSR ones are 5,5.
Besides that I noticed one of the dampers is not moving freely, it feels like the piston binds. After measuring I found that specific piston is not nice and round, and leaves to much free movement to the piston / rod assembly. This can then bind on the wall of the cylinder. Are there upgrade pistons available? Or should I order a set of stock ones, is my off-spec one a freak accident?
Cheers,
Hugo
HugoW is offline   Reply With Quote
Old 05-31-2017, 10:25 PM   #467
Phil Trotta's Avatar
I have two of these cars built for sale used one day .... Message me if interested
125.00 for both. No bodies. No elec. rolling chassis on gravity rubber
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 06-11-2017, 06:58 PM   #468
Race day #3.
Round 1
https://youtu.be/OgeCCuMCFNw
Round 2
https://youtu.be/atvDDShymTM
Billy Kelly is offline   Reply With Quote
Old 06-20-2017, 02:14 AM   #469
Would someone be so kind as to use a pair of calipers and measure the diameter of the balls on the lower suspension arms, the ones that you fit the sway bar joints to? My car is still at the club and I want to order the final parts to put the sway bars in action.
Cheers,
Hugo
Old 06-20-2017, 09:22 AM   #470
massenb203's Avatar
Actual size is 4.9mm so it would be consider to be a 5mm ball stud.
Henry Massenburg
Team C Racing USA, TC10 2015
Ho-B Max RC Park
massenb203 is offline   Reply With Quote
Old 06-20-2017, 10:57 AM   #471
Thanks!
Old 06-21-2017, 05:14 AM   #472
I bought this set, which is for a different car:
https://hobbyking.com/en_us/stabiliz...ar-4-sets.html
And the swaybars and sway bar mount TU1040. It will all probably fit, although I don't know if it will fit the 4,9mm balls on the lower suspension arms. Worst case I need to buy separate connectors for that. But the rest of the set is certainly usable and there is another advantage for me; the set is in the EU warehouse, just like the sway bars them selves. And since the next race is coming Tuesday, I have a better chance of receiving the bits this week then when ordering them from China.
Cheers,
Hugo
Old 06-21-2017, 08:03 AM   #473
massenb203's Avatar
Cheers,
Hugo
Yes the will probably work but as a reminder that the front sway bars is shorter than the rear on this car.
Henry Massenburg
Ho-B Max RC Park
Old 06-25-2017, 02:02 PM   #474
Race day #5.
R1
https://youtu.be/9PN9wCHDOOQ
R2
https://youtu.be/EqYGKuvBgGA
R3
https://youtu.be/AzvyFNanaiI
massenb203 likes this.
Old 07-10-2017, 10:31 AM   #475
Race day #6. Low turnout so combined all rounds to 1 video.
https://youtu.be/QdHHdsH46ls
Old 07-11-2017, 03:47 PM   #476
Originally Posted by tonybod View Post
If it helps, I uploaded a FDR chart some time ago for the BT-4,
R/C Tech Forums - View Single Post - BSR Racing BT4 Budget Touring car kit
Thanks. I knew I'd seen this somewhere. Last gearing change worked, but not as expected. I see why now.
The belt pulleys on the sides of the spur gear. Anyone found a aluminum replacement? I'm starting to see wear on mine
Old 07-11-2017, 04:28 PM   #477
I absolutely enjoy driving this car, only change I have made out of the box is swapping to 64 pitch gears, putting on the "hard" c hubs and putting the aluminum upgrades from team c racing on.
Sponsors:
Team C Racing ,Bellgate Distributors,Dialed Hobbies,Boca Bearings,Cowrc,Raw Speed
countryboyzrc is offline   Reply With Quote
Old 07-17-2017, 12:12 PM   #478
kamlooper's Avatar
Sale on now at Hobbyking on parts and the ARR version. Im tempted on the arr, but I know Ill have to tear it down and re assemble it. Much prefer a kit.
Drift_Buggy likes this.
kamlooper is offline   Reply With Quote
Old 07-17-2017, 09:19 PM   #479
They are well assembled from factory. I've been racing my 21.5 RTR version all summer. No issues. And my 13.5 model has been problem free, not raced.
Old 07-18-2017, 01:44 PM   #480
E1 Diablo's Avatar
Just purchased the ARR version. Only $30 more than the kit and includes, servo, esc and motor.
Anyone know if the included servo is okay for racing? TrackStar TS-D99X 10kg servo
E1 Diablo is offline   Reply With Quote
