Like Tree23Likes
Old 03-14-2017, 04:53 PM   #421
I run 69/36, track is a larger flowing track. A lot of people run over 4FDR but iv found I need to be in mid to low 3s to keep up with their top speeds.
I don't run timing or anything, temps are 38'c.
One bloke comes off at 90'c
NITROBUSA is offline   Reply With Quote
Old 03-14-2017, 06:47 PM   #422
I've got 35/69 in mine.
Billy Kelly is offline   Reply With Quote
Old 03-16-2017, 07:41 AM   #423
Originally Posted by schufab View Post
Vbc diff is complete, or only housing?
Is this part D-05-VBC-0014 or D-05-VBC-0053
Please, Help Me ! Thanks !
schufab is offline   Reply With Quote
Old 03-20-2017, 12:19 PM   #424
Originally Posted by massenb203 View Post
On a asphalt track, I would start with a 3.8 FDR using a 83 tooth 48 pitch spur and a 44 tooth 48 pitch pinion with this motor and go from there checking your motor temp after 2 minutes of running.
So I just got the kit mid last week and did my first ever practice session (between club qualifying and racing none the less), on used hand me down tires.
I am thoroughly impressed with this $100-125ish kit, I was able to run the same times as the guy that finished 8th out of 10 racers. Everyone except for one racer ahead of that guy was driving a Serpent, XRay or Yokomo.
I sadly was unable to find any 48P Pinions so had to ditch the 48P Spur and go with a 64P combo. I bought the following combo from a racer onsite 52Pinion/84Spur (64Pitch) and after a 7 minute session came off track at 154 deg.
What does that mean FDR wise? Heat wise?
My thoughts were - It was way too easy coming out of corners full throttle and on the straight I was maxing out on top end before the 1/2 marker on straight.
Any feedback is greatly appreciated as I try to get this sucker up closer to Top 5 in this very competitive field.
CaptSlow is offline   Reply With Quote
Old 03-20-2017, 12:20 PM   #425
Furthermore - I raced in the USGT class and the wheels/tire combo others were running is what I tried to run but it had a lot of rub (wheel rubbing on part with 3 holes), and two of the racers said, they just dremel/sand that part down so the wheel does'nt rub. Is that normal?
Old 03-20-2017, 04:55 PM   #426
massenb203's Avatar
FDR is your Final Drive Ratio which is a 3.07:1 with the gear you currently have. 154 degrees temperature after seven minutes of run time is good and you can go down a couple more teeth on the spur gear and add a fan.
CaptSlow likes this.
Henry Massenburg
Team C Racing USA, TC10 2015
Ho-B Max RC Park
massenb203 is offline   Reply With Quote
Old 03-20-2017, 04:58 PM   #427
massenb203's Avatar
You can change the standard 12mm wheel hex that is 5mm thick to a 6mm thick hex.
Henry Massenburg
Ho-B Max RC Park
Old 03-21-2017, 08:23 AM   #428
I wouldn't change the FDR . Remember that the straight is only 1/3 of the the track. The infield is where you need the extra speed coming out of the corners
Slapuchuck is offline   Reply With Quote
Old 03-28-2017, 09:21 AM   #429
Johnn27's Avatar
Trader Rating: 71 (100%+)
Questions?? aluminum motor mount
can anyone recommend which aluminum motor/spur gear mount might fit this car? is it even needed ?
Johnn27 is offline   Reply With Quote
Old 03-28-2017, 06:16 PM   #430
massenb203's Avatar
The motor mount needed is the TC10 Alum mount. Part Number is T01137.
Henry Massenburg
Ho-B Max RC Park
Old 03-29-2017, 07:28 PM   #431
Johnn27's Avatar
Questions??
I checked Hobbyking and they are out of stock but I can back order the mount.
Anyone know of any other sellers that might have it in stock or anyone have any experience back ordering from Hobbywing? I Checked eBay but there is only one and the seller is asking a crazy price.
Old 03-29-2017, 08:02 PM   #432
Johnn27's Avatar
Questions?? FDR
Anyone know what the final drive " FDR" is for this car also? I want to run it 17.5
or suggest a spur size in 48p
Old 03-29-2017, 08:11 PM   #433
gigaplex's Avatar
FDR depends on the spur and pinion. I think you're asking for the internal drive ratio. I'm pretty sure that's 1.9.
gigaplex is offline   Reply With Quote
Old 03-29-2017, 08:20 PM   #434
massenb203's Avatar
This car has a 1.9 Ratio. Your FDR would depend on the track size however you can try a 72 teeth 48p spur with a 32 teeth 48p pinion which will give you a FDR of 4.27:1 ratio.
Henry Massenburg
Ho-B Max RC Park
Old 03-29-2017, 08:49 PM   #435
Johnn27's Avatar
Thumbs up Ratio
Ratio yes this is what I was looking for thank you!
