Old 11-09-2005, 12:50 AM   #1
Default converting TC3 to TC4
Sorry if this has been asked before, but a search did not find the thread.
I have converted my TC4 to a 3 racing graphite chassis so I am left with a hardly used TC4 chassis tub.
Can I simply build my tc3 components on to this, and change things like suspension arms as and when they break (!) or do I need to buy a lot of new parts?
I think off the top of my head, only the steering mechanism should need changing?
Thanks all
AEDave is offline   Reply With Quote
Old 11-09-2005, 03:00 PM   #2
You will not be able to use the TC3's A-arm mounts on the TC4's chassis (screw holes are spaced differently). And with the different sized inner hinge pins, you may end up not being able use most of the TC3's suspenion parts.
LJae is offline   Reply With Quote
Old 11-10-2005, 12:50 AM   #3
thanks LJae, thought there might be more problems than I first thought! will stick to the TC3!!!
Converting a MF2 convikt Electric Off-Road 2 12-08-2007 12:43 PM
Converting to Pro Kit Chevron89 Nitro Off-Road 9 07-12-2007 09:36 PM
Converting 4WD To 2WD Toolbox™ Electric On-Road 7 01-28-2007 06:29 AM
Converting an XR 80 to the XR8 llamont Nitro On-Road 16 09-06-2006 06:05 PM
Converting a BK2 to a XXX-CR pvtysux Electric Off-Road 31 07-27-2006 06:20 PM
SEO by vBSEO 3.5.0
