Old 11-05-2005, 07:11 PM   #1
f2000racer's Avatar
Default Help with Integy 16x8x6 charger/dyno
Just want to check if anybody have this problem (or if this a problem) with the Integy 16x8x6 charger dyno combo.
Problem is I want to cycle a one heat used battery,
use the discharge to charge function,
simply charge a dead shorted battery...
I keep on getting the same error... please see attached picture.
Sometimes I'm able to charge but most of the time it doesn't work. I only had this for a week and just started to use it, no race action yet.
Hope anybody here can help
Help with Integy 16x8x6 charger/dyno-picture-002.jpg
Tamiya F103RM
Tamiya Mini
Tamiya TA05
f2000racer is offline   Reply With Quote
Old 11-05-2005, 08:04 PM   #2
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
i have had the same error. i usually just try to charge again, and it'll go away. pretty gay, though. are you using the internal power supply? i suspect that using an external p/s would alleviate this problem. unfortunately, i am not sure what is causing this. low line voltage??
- chris -
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 11-05-2005, 09:13 PM   #3
rinkrat99's Avatar
Send a message via AIM to rinkrat99
I ran into that problem tonight with the 16x7 charger. I found that my Power Supply was outputing 11Vdc at the output and then the charger under laod was reading down to 10V. Meaning you have either a large voltage drop between PS and charger or your PS is putting out less than 11V.
Good luck, I am looking for a new PS.
BTW - I also ran into problems with the AC from some generators at the track causing glitches and noise therefore the charger was shutting down and/or false peaked. Integy doies not have a solid PS built in to there chargers.
rinkrat99 is offline   Reply With Quote
Old 11-06-2005, 02:23 AM   #4
Their manual says the AC outlet need a minimum of 110V, they also mentioned about using an seperate 12V power supply.
RickyIS300 is offline   Reply With Quote
Old 11-06-2005, 03:26 PM   #5
f2000racer's Avatar
Thanks for all the replies. Seem to be a problem with the internal power supply. Also better check the power in my home.
This is no good
Tamiya F103RM
Tamiya Mini
Tamiya TA05
Old 11-06-2005, 04:04 PM   #6
XrayFK's Avatar
Try using a 13.8V power supply, that might help. I've heard of people having input errors when using power supplies that only put out 12V (computer ps)
XrayFK is offline   Reply With Quote
Integy charger 16x8x6 ver2 olhipster1 R/C Items: For Sale/Trade 5 06-20-2008 08:22 PM
Integy 16X8X6 Multi Purpose Charger jrxsracer R/C Items: For Sale/Trade 3 02-28-2008 04:06 AM
INTEGY 16X512 charger w/dyno!!!! RCcmpr R/C Items: For Sale/Trade 6 07-18-2007 07:47 AM
INTEGY 16X8X6 V2, NOVAK, BUDS, 12L4, GP4300, GP3700 LOSIMANJRXS R/C Items: For Sale/Trade 50 07-16-2006 12:02 PM
Integy Dyno / Charger / 0-30 A. Rhodes R/C Items: For Sale/Trade 4 05-22-2006 03:19 PM
SEO by vBSEO 3.5.0
