Old 10-23-2002, 10:09 PM   #1
Default air gap & foam insert
Can someone advise what is the significant of Air Gap between foam insert and tyres ?
Noticed that the newer inserts seems getting thinner and thinner.
ongbenghui is offline   Reply With Quote
Old 10-24-2002, 01:55 AM   #2
sosidge's Avatar
The air gap is supposed to increase traction, it'll let the tyre "flex" a bit mor when you put down the power.
Old 10-24-2002, 02:01 AM   #3
ijnek's Avatar
Send a message via ICQ to ijnek
read abt this b4,...but can't remember which mag...
if i'm not wrong,u can make the hole in the wheel rims bigger 2 increase traction...
but always know tat more grip= shorter life span...
if u wan bigger inserts,can try speedmind full profile inserts...
ijnek is offline   Reply With Quote
Old 10-24-2002, 01:01 PM   #4
From how I understand it, more airgap means more flex which means more traction. (think of the "wrinkle wall" tires on a dragster)
If you want to get rid of airgap, either use a bigger insert or wrap tape around the rim until it feels good.
JeffC is offline   Reply With Quote
Old 10-24-2002, 02:28 PM   #5
Im2lazy's Avatar
or you could use something like Trinity's Bomb gllue (for tire inserts) to gllue the insert to the wheel as well as the tire carcass if you want. You could also use slightly wider rims or inch ups to decrease the airgap.
Having an airgap in the tires is a drivers preference. i like a little, but if ihave no air gap, the inserts seem to heat faster.
For my sorex 36's, I like to buy 26mm standard rims and HPI 24mm inserts, this gives just a little less air gap then usual.
Im2lazy is offline   Reply With Quote
Old 10-24-2002, 03:12 PM   #6
ruf's Avatar
Send a message via AIM to ruf
Glueing the insert to the tire constitutes a capped tire which is illegal for ROAR and IFMAR touring.
I've actually noticed the opposite trend of fatter inserts. I still prefer Yokomo inserts over all the newer, fuller inserts. The baginess makes the car a little more predictable at the expense of slightly irregular tirewear.
Joe Chen
ruf is offline   Reply With Quote
JB Foam (tire insert) What Online Hobby Shop Carries these noline Electric On-Road 10 10-24-2010 12:53 PM
Foam Insert Cutting/Firmness tricks for oval z28mccrory Oval, Larger Scales and More 0 03-03-2008 07:02 AM
REX P5 with NEW TKO 8mm insert bellto R/C Items: For Sale/Trade 0 10-27-2006 09:39 AM
which insert?? piorc Electric On-Road 0 02-21-2005 02:52 PM
which insert ?? piorc Electric On-Road 0 02-21-2005 02:51 PM
SEO by vBSEO 3.5.0
