    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800 (Electric Touring Car)
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Like Tree148Likes
Old 10-08-2015, 03:17 AM   #61
TENCHO's Avatar
i have a a700, and with my satisfaction with it, i will like to buy the a800, just for the sake of collecting it. no matter how well it performs. just like i have a TRF415, 416, 417, 418, 419....i'll get the 420 and on and on....and i' would pre order it no matter how it looks
xray guys do the same thing....t3, t4, i'm sure they'll get the t5 and on and on...
Jesus Sierra-
Stock Touring 17.5-TamiyaTRF416/Exotek/SpecR mix
VTA-SpecR R1/Novak Ballistic 25.5
F1-VBC LightningF
TENCHO is offline   Reply With Quote
Old 10-09-2015, 05:36 AM   #62
hanulec's Avatar
Trader Rating: 27 (100%+)
3 day national holiday this weekend in Taiwan. hopefully we'll have some exciting updates starting Monday..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-09-2015, 02:04 PM   #63
yumlailai's Avatar
When's the release date? I just pre-ordered it on the web site last night.
yumlailai is offline   Reply With Quote
Old 10-10-2015, 12:31 PM   #64
Penz316's Avatar
Can wait much longer
Alex Fournier
Team Associated | Reedy | Team Scream Racing | Hyper Hobbies
Penz316 is offline   Reply With Quote
Old 10-11-2015, 04:51 PM   #65
hanulec's Avatar
Another teaser for you all...
https://m.facebook.com/story.php?sto...&id=1823844510
Old 10-11-2015, 05:36 PM   #66
dc661's Avatar
Trader Rating: 123 (100%+)
Originally Posted by hanulec View Post
This definitely makes me want one.
-DJ Cranmer
dc661 is offline   Reply With Quote
Old 10-11-2015, 09:22 PM   #67
Schwarta's Avatar
Makes me annoyed that I've only had my Evo2 for a few months and it'll be out dated!!
Schwarta is offline   Reply With Quote
Old 10-11-2015, 09:55 PM   #68
nexxus's Avatar
Trader Rating: 301 (100%+)
I'm with you there! Half the reason I gave up on Xray
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 10-11-2015, 11:20 PM   #69
Just because a new car is coming out does not mean that your current one needs to go in the trash, it is still competitive. Being slightly optimistic, maybe there will be a conversion kit.
Patrick
XCELL is offline   Reply With Quote
Old 10-12-2015, 02:30 AM   #70
Schwarta's Avatar
Patrick
I know!! I just like new and shiny!!
Be interesting to see if it's just a belt drive (minus the floating gearbox) with the same suspension. I wonder how the motor will mount?
Old 10-12-2015, 03:25 AM   #71
I am looking forward to this car as well it should share the same suspension as the current car, but just belt driven. Hopefully we will see it very soon.
Patrick
Old 10-12-2015, 04:06 AM   #72
howardcano's Avatar
Trader Rating: 35 (100%+)
Patrick
But if you do decide to throw away the old one, I'll be hiding in the dumpster.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 10-12-2015, 06:05 AM   #73
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
My Evo1 is still competitive. Only the driver is holding it back.
Dan is offline   Reply With Quote
Old 10-12-2015, 08:09 AM   #74
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Patrick
I rather buy new than conversion kit
for reason it is fresh and no rebuilt and less time and cheaper and No headache...lol
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-12-2015, 09:29 PM   #75
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
No spy shots of that Beltomatix yet ?
