    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800 (Electric Touring Car)
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Like Tree148Likes
Old 10-01-2015, 09:49 AM   #16
If it is a belt drive, then Oleg would have created a car that can be any drive you want to run, whether shaftdrive for spec racing or belt drive for mod racing... That would also more than double the Awesomatix market... I think they might also sell a belt conversion kit for those who already own the shaft version, and would like to add the belt version to their stable.......
bertrandsv87 is offline   Reply With Quote
Old 10-01-2015, 10:09 AM   #17
gijoe64's Avatar
Trader Rating: 30 (100%+)
Well just take my money!!!!!!!!!
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 10-01-2015, 10:18 AM   #18
Trader Rating: 49 (100%+)
somehow I think this will be too different for a conversion. Besides, you are all about shaft drive.... why would you bother?
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 10-01-2015, 10:45 AM   #19
First pictures and info here
http://www.thercracer.com/2015/10/aw...irst-look.html
Cheaper sounds like a good start. Although I would be interested to see what other changes there are from the 700. As others mentioned it seemed to be a quick car off from the bat but it's never really had that edge to beat other conventional cars (in the uk).
Qatmix is offline   Reply With Quote
Old 10-01-2015, 10:58 AM   #20
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Here Ya go
Yes it is an old pic
OVA is offline   Reply With Quote
Old 10-01-2015, 11:24 AM   #21
Looks intersting, but that is an old conversion mate
I'm interested to see how / where the motor fits etc in the new design.
Old 10-01-2015, 02:36 PM   #22
I am only about shaftdrive, but I also understand Oleg's good business decision... Associated did the same, and still have both shaft and belt drives... AE and Awesomatix have my full support...
Old 10-01-2015, 02:44 PM   #23
patorz31's Avatar
Well it should be cheaper and less part on the week to make the shaft drive feel more like a belt car. I am liking the belt drive idea, with the A700 Suspension.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 10-01-2015, 03:09 PM   #24
hanulec's Avatar
Trader Rating: 27 (100%+)
I like to call the upcoming drive system Zak Propulsion. Please formulate your own opinions / guesses / theories.
We've been hoping to debut the car at the 2015 Halloween Classic ... But things just didn't come to plan.
Once more info can be made public-- it will be. Sorry to everyone who as PMd, called, emailed, etc. Pre-order will also be setup as soon as everything is finalised.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-01-2015, 04:52 PM   #25
Oh Lazer beams I like it
2uzferunner03 is offline   Reply With Quote
Old 10-01-2015, 08:37 PM   #26
DesertRat's Avatar
Looks like a great machine.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 10-01-2015, 09:11 PM   #27
josecarlo1129's Avatar
Originally Posted by patorz31 View Post
Maybe he is running Helical cut gears and moved the shaft really low on the chassis?
Well, better stick with your VBC.
Glad, I'll be enjoying both 'shaft' and 'belt' system courtesy of Awesomatix now. Surely, this will be great.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 10-02-2015, 06:52 AM   #28
hanulec's Avatar
Preorder available now
http://shop.awesomatixusa.com/awesom...uring-car.html
Old 10-02-2015, 07:20 AM   #29
Bar
Shaft drive then!
Luke Burr
Bar is offline   Reply With Quote
Old 10-02-2015, 07:29 AM   #30
Originally Posted by hanulec View Post
Wow!
