    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800 (Electric Touring Car)
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Like Tree148Likes
Old 08-10-2017, 11:02 PM   #2731
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
So to reply to my above post the replacement O-rings i found for the OR152. The company is called LYNX and the part # is LX1506A. Comes with 10 in the pack. Also works great keeping the shock rod tight to the shock arm. I refuse to talk code or part numbers when describing parts.
Oh and you can get them at Amain.
Josh-n-ya is offline   Reply With Quote
Old 08-11-2017, 03:25 AM   #2732
geeunit1014's Avatar
Originally Posted by DPRacing View Post
Hello,
Does anyone have a small overview of hardness (viscosity) LRP oil vs. Muchmore oil? For the dampers
best regards Daniel
Unfortunately I think this information is going to be hard to come by. Your best bet is to stick to one brand of oil so you don't confuse yourself with the different labeling of different brands
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 08-11-2017, 10:38 AM   #2733
Does anybody use the P06-1 Downstop collar? I didn't get them in my kit but saw them in my manual.
KyleC1 is offline   Reply With Quote
Old 08-11-2017, 11:26 AM   #2734
hanulec's Avatar
Trader Rating: 27 (100%+)
In an X car.. this part is replaced with the P12X
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-11-2017, 12:28 PM   #2735
Thanks! Do you by chance have any tips for making the front universals... I can't seem to get them in.
Old 08-11-2017, 12:50 PM   #2736
hanulec's Avatar
search is your friend. already been answered-
R/C Tech Forums - View Single Post - Awesomatix A800 (Electric Touring Car)
Old 08-11-2017, 01:52 PM   #2737
oldrcr's Avatar
Trader Rating: 43 (100%+)
Default Turnbuckle ball cup assembly tool
I had found some O-rings from a place that had repair parts for air sprayers and similar equipment. Not sure if those kinds of places are common, or if I just got lucky that they had some similar in size. The silicone heli part ones from LYNX look nice, will have to order some to try.
Just saw a tool that Jake made for putting together turnbuckles that make the pain of holding the ball cups much easier on the fingers. Nice. Go to Speedzombi.com website and you can see one in action.
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 08-14-2017, 03:35 PM   #2738
Originally Posted by geeunit1014 View Post
The X mount is taller to fit with the taller bulkheads/topdeck
Interested, I have an A800. How much higher are the X bulkheads and what was the thinking here? I take it that also raises the suspension top links for any given shim setup?
Mark
Mark Payne is offline   Reply With Quote
Old 08-14-2017, 05:56 PM   #2739
nexxus's Avatar
Trader Rating: 301 (100%+)
Mark
The X bulkheads are 0.5mm taller. also the AM06WSL are 0.75mm taller than AM06W
So to get the same roll centre (roughly) I was running 0.5mm less shim on the bulkhead and 0.75mm less on the hub, but this doesn't factor in that the actual axle is sitting higher not just the camber link
tandman likes this.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 08-14-2017, 07:08 PM   #2740
Trader Rating: 18 (100%+)
Currently running a TC7.1 and have great results with it but the Awsomatix has always piqued my interest. A few locals are on the Serpent 4X bandwagon but getting parts kills that for me.
Where are the best places to get parts other than direct? Just want to get an idea how many options I'll have coming from Associated...
iTz Nicholas72 is offline   Reply With Quote
Old 08-14-2017, 08:01 PM   #2741
Osiris 75's Avatar
Trader Rating: 17 (100%+)
https://www.tqrcracing.com/shop/prod...s_maker_id=128
Awesomatix USA
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
CAPRICORN USA / REFLEX RACING
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old Yesterday, 06:29 AM   #2742
Josh-n-ya's Avatar
Seems to be a shortage of Muchmore #500 shock oil.
Old Yesterday, 09:47 AM   #2743
hanulec's Avatar
The USA team runs AE oil. Unless your looking to copy the tires + surface... I'd recommend you not worrying about MM oil
Old Yesterday, 10:55 AM   #2744
Josh-n-ya's Avatar
I'm not part of the team. Been using Muchmore oil for a few years now. Very smooth stuff.
Old Yesterday, 10:59 AM   #2745
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I think Hanulecs point is that if you want to copy or use the USA team's setups your best bet is to buy the super cheap AE oil, the CST of MM and AE may be hundreds to thousands of points off. I'm too lazy to look though.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
