    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800 (Electric Touring Car)
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Like Tree94Likes
Old 05-17-2017, 01:50 AM   #2566
Default sway bar
hello, soon to be owner of a new 800xa
how you adjust sway bar tweak on 800xa ?
on X-ray t4 this is very easy,just adjust the end link height and your all done..
i also see these new shock parts recently come out at78 damper piston with o-ring instead of foam insert..is this a must have? many of you struggle with leaking shocks?
magstaff is offline   Reply With Quote
Old 05-17-2017, 05:20 AM   #2567
geeunit1014's Avatar
You just center the bar and that is it. No other way to adjust the bar.
I never had any big problems with the shocks, just be sure to theeadlock the set screw that holds in the spr02, if this screw becomes loose then the shocks will leak, not to mention the suspension will not work properly.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 05-17-2017, 06:18 AM   #2568
ok thanks ...good advice with the threadlock..
but i think it is somewhat strange that this advanced high tech rc dont have any adjustability regarding tweak in swaybars,guess/hope that probably will come in the future..
but maybe if everything is tweakfree and swaybars are perfectly centered there will be little to no tweak.
Old 05-17-2017, 10:58 AM   #2569
Default ..
Some more thinkering about the build of 800xa.
Some pointers that concern me:
1)
grinding of rear driveshafts st02 to remove binding
2)
When mounting the bulkheads and motormount to the chassis, please use a reamer to make a very small chamfer on the small holes. The Pins on the bulkhead have a very small radius from milling, without the chamfer this radius might have contact with the chassis before the bulkhead is screwed fully tight and may not sit properly.
3)
Fitment issues with outdrive st23 pin02 and b106 bearing on the diff. grinding of some material from the b106 bearing is the solution.
Some modifications is ok ,but these problems are the one i really would like to avoid..
Is this problems from the past, or are people still modifying these areas on new kits ?
Old 05-17-2017, 01:17 PM   #2570
Trader Rating: 40 (100%+)
I built mine without any difficulties or issue without any of those mods.
1)
2)
3)
v_squared is offline   Reply With Quote
Old 05-17-2017, 01:32 PM   #2571
Ivan Dickson's Avatar
Trader Rating: 9 (91%+)
Thumbs up No issues with the 800X build
Me to as well..
SPECIAL THANKS TO ✦ MY WIFE ✦✦ GLOBAL PRIVATE FUNDING ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 05-18-2017, 04:04 PM   #2572
Originally Posted by nexxus View Post
I run it on the 2.25 chassis std A800 and it is great, on the A800X chassis which has a lot more flex, you need to really stiffen the bottom to get it to work otherwise you get a lot of chassis roll which absolutely slams the lower deck, see the below for wear after 6 race meets in 21.5 and thats at a ride height of 6/6.3 My A800 has done around 20 meets in 13.5 and 21.5 on the same track, similar shock / suspension settings and no where near this level of wear
You really should be running anti roll bars on that track. It will help immensely.
RCMAKER | BITTYDESIGN | MUCHMORE
Lionel S is offline   Reply With Quote
Old 05-18-2017, 06:04 PM   #2573
nexxus's Avatar
Trader Rating: 299 (100%+)
Tried them, used to run 1.1 front and rear then tried 1.0, and the car works better without them as grip is very very low.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 05-18-2017, 06:48 PM   #2574
hanulec's Avatar
Trader Rating: 25 (100%+)
1)
2)
3)
all of these items were work arounds for bad part runs. these bad fitting parts have been eliminated and anyone w/ them have had replacements sent.
josecarlo1129 and magstaff like this.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-18-2017, 09:28 PM   #2575
MaxSp97's Avatar
Mike,
Can you post the Camarillo setup?
Thank you,
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 05-18-2017, 11:10 PM   #2576
Is there a big difference between the khaki ali and 2.25 carbon chassis flex wise guys? Running on low traction asphalt.
Glarke is offline   Reply With Quote
Old 05-19-2017, 04:19 AM   #2577
hanulec's Avatar
Originally Posted by MaxSp97 View Post
Mike,
Thank you,
I'll write it up at the track on Saturday
Yes
Alloy Chassis+ vtd is more similar to 2.25 carbon + std top deck
Glarke likes this.
Old 05-19-2017, 12:01 PM   #2578
spring71's Avatar
Smile
Awesomatix A800X kits and more parts arrived at TQ.
https://www.tqrcracing.com/shop/prod...s_maker_id=128
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 05-21-2017, 11:33 AM   #2579
I had kind of a weird defect today, has anyone experienced something similar?
On my first Final the rear was very loose and I had to drive slower and more cautious to finish the race. Fell from first to third, ouch! First I blamed the Volante tires because I had some problems in the past with them, but after the run I had to realize that the diff was fully locked! No movement at all.
Turned out one of the output axles (ST31) was stuck inside of the diff housing (AT124B). I had to use a hammer to drive it out and use a 4 mm file to widen the hole enough, so ST31 would fit without binding.
I hope that doesn't happen again.
Rincewind is offline   Reply With Quote
Old 05-21-2017, 12:31 PM   #2580
This happened to me also,this due to the tolerance and afterwards coating, my second car did not experienced this problem because i put first grafiet into the hole and tested if it binds or not.
Do not forget to grease it before assembly, probably you did it already.
eded1 is offline   Reply With Quote
