    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800 (Electric Touring Car)
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Like Tree123Likes
Old 03-20-2017, 11:28 AM   #2401
Trader Rating: 43 (100%+)
Anybody know when we'll see more in stock?
v_squared is offline   Reply With Quote
Old 03-20-2017, 01:01 PM   #2402
hanulec's Avatar
Trader Rating: 27 (100%+)
The question everyone wants to know... Including me
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-20-2017, 01:20 PM   #2403
Pass the word on. I'm willing to donate time on the production line to help get some kits out the door. I will even help with packaging and shipping.
Old 03-20-2017, 05:24 PM   #2404
dawgmeat's Avatar
Originally Posted by hanulec View Post
write up better later than never - Awesomatix USA: Burt, Sydor and Kao win at 2017 Snowbird Nationals
roar nats write up in the next 12h or less
Even though I couldn't finished the Birds' last qualifier and main due to family issues. I used an A800 #9 Starling Gibson
dawgmeat is offline   Reply With Quote
Old 03-20-2017, 06:25 PM   #2405
nexxus's Avatar
Trader Rating: 299 (100%+)
Anyone having bearing issues? My A800X has done 4 meets now, and I put in Plaig Ceramics during the build, the front left bearing on the spool seized up on me last race, and when I went through it, 3 other bearings were borderline, the left hand side on the rear diff and both bearings on the back left hub.
A800 / A800X Awesomatix
Fry crack corn and I don't care,
Leela crack corn, I still don't care,
Bender crack corn and he is great!
Take that you stupid corn!
nexxus is offline   Reply With Quote
Old 03-20-2017, 07:17 PM   #2406
hanulec's Avatar
u need to oil bearings. i have zero experience w/ plaig bearings ... but in general, not oiling before install is setting yourself up for failure
Old 03-20-2017, 07:29 PM   #2407
gigaplex's Avatar
Plaig bearings come pre-packed with grease.
gigaplex is online now   Reply With Quote
Old 03-20-2017, 07:37 PM   #2408
nexxus's Avatar
And I always apply Trinity Royal Oil to bearings prior to fitting them to the car.
Old 03-20-2017, 07:38 PM   #2409
hanulec's Avatar
so did the AMTX kit bearings for 3+ years until they didnt. then there were a bunch of reports of seized bearings due to a manufacture sub-component issue.
ill continue to recommend that people -- #1 degrease their bearings & #2 oil appropriately
Old 03-21-2017, 07:01 AM   #2410
celt's Avatar
Bearings aren't even a thing for me anymore...take care of them the best you can and when they go, they go.
Disposable...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 03-21-2017, 02:35 PM   #2411
Disposable...
Same here.... Three bearings is nothing... I have gone through twenty in about five meets... I love the boards too.....lol....
bertrandsv87 is offline   Reply With Quote
Old 03-23-2017, 06:09 PM   #2412
hanulec's Avatar
Awesomatix kits are starting to hit distributors after being unavailable for some time now.
Old 03-23-2017, 08:20 PM   #2413
All because I went to work on the production line.
Old 03-24-2017, 09:49 AM   #2414
ZEe_NYC's Avatar
Trader Rating: 24 (100%+)
there's a used car currently on eBay, for anyone that's interested.
what's an analog?
ZEe_NYC is offline   Reply With Quote
Old 03-24-2017, 03:45 PM   #2415
crabboy's Avatar
Trader Rating: 58 (98%+)
F
Rhys Marshall.
crabboy is offline   Reply With Quote
