    Hide Wikipost
Old 01-12-2017, 07:43 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Awesomatix A800
Last edit by: Sam Isaacs
Welcome - please help to make this Awesomatix A800 wiki useful!
A800 Information
New Parts
  • June 2016: A800-SPR01-98 - The version of SPR01 springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • June 2016: A800-SPR01S-98 - The version of SPR01S springs with reduced angle of the tips bending. Recommended for using with new SPR02H3 Shock Rod Guides.
  • May / June 2016: A800-AM14A - includes new optional "longer" hole on steering arm
  • May / June 2016: A700-AM14-3 - removes the prior "longer" hole on steering arm
  • May / June 2016: A800-C04AL+0.5 - 0.5mm wider alloy suspension arm
  • May / June 2016: A800-C01B-2.25 - 2.25mm carbon main plate (best suited for asphalt racing)
  • May / June 2016: A800-D2.2 - Dampers that support a thicker SPR02H3
  • May / June 2016: A800-SPR02H3 - Thicker Shock Rod Guides for the D2.2 damper
  • May / June 2016: A800-AT41-2 - Damper vane for the D2.2 damper designed to work w/ SPR02H3
  • May / June 2016: A800-SPR02H - Stronger Shock Rod Guides for the D2.0 and D2.1 damper versions
  • May 2016: A800-AM19-4 - Currently used in the rear of a kit. With AM19-4 the top link effective length is 0,7mm shorter compare to AM19-2. Also with AM19-4 the flex of suspension is smaller ( similar to more stiffer arm and c-hub of normal cars). The screws on dampers are more accessible for adjustment.
  • January 2017 - SPRO2X - new for dampers and do not require a 98 degree bent spring.
  • January 2017 - New A800X and A800XA kits now available featuring 0.3mm longer front and rear wheelbase.
Kit Updates
  • May - Current: Kits now including DT10-2-1 bearing holders for increased side play and durability of the differential and spool.
  • May - July 2016: bearings within kits require oil before use
  • May / June 2016: C01B-AL (Khaki) Chassis with 0.5mm/side wider front arm mounts
  • May / June 2016: 2x ST17-1-S replace ST17 - See page 21 of manual
  • May / June 2016: Updated damper, D2.2, introduced
  • May / June 2016: Thicker Shock Rod Guides for the D2.2 damper included with kits, A800-SPR02H3
  • Jan 2016: GD2 Output Axle (ST31-1) update to use blue foam (P46) instead of set screw (used on each side of Axle after assembly)
Setups
Major Race Wins
  • 2016 Reedy Race of Champions - Modified - Julian Wong
  • 2016 Mile High Championship - 17.5 - Kyle Klingforth
  • 2016 Mile High Championship - 13.5 - Kyle Klingforth
  • 2016 ROAR On-Road Carpet Nationals - 17.5 - Mike Gee
  • 2016 ROAR On-Road Carpet Nationals - 13.5 - Mike Gee
  • 2015/6 ETS Season 9 Round 3 - Xray Pro Stock Division - Tony Streit
  • 2015 US Indoor Champs - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 13.5 - Mike Gee
  • 2016 Roar On-Road Asphalt Nationals - 17.5 - Sam Isaacs
  • 2016 International Indoor Championships (IIC) - 17.5 - Mike Gee
  • 2016 Halloween Classic at the Gate - 17.5 - Brad Johnson
  • 2016 US Indoor Champs - 17.5 - Sam Isaacs
  • 2016 US Indoor Champs - 13.5 -Matt Lyons
  • 2016 Stock Wars - 17.5 - Mike Gee
  • 2016 Hudy Indoor Championship - 17.5 - Brad Johnson
Print Wikipost
Like Tree179Likes
Old 07-20-2017, 10:31 AM   #2701
MostlyTorso's Avatar
I just PM'd you.
MostlyTorso is offline   Reply With Quote
Old 07-20-2017, 11:59 PM   #2702
Josh-n-ya's Avatar
Trader Rating: 75 (100%+)
Originally Posted by MostlyTorso View Post
I just PM'd you.
I race with MostlyTorso. Clean 700evoII he has for sale. Both carbon and aluminum chassis come with it.
Josh-n-ya is offline   Reply With Quote
Old 07-21-2017, 10:39 AM   #2703
Thanks to everyone for the responses and feedback. I was able to find a great car on here (Thanks Jessele) so I'm covered for right now. I'm anxious to see how the A700 does compared to my A800. I run VTA and USGT so if there is enough performance difference and efficiency gain, I might have to snatch up another A700.
I'll post an update on the A700 thread once I get everything sorted out and tested.
Thanks again to everyone
Josh-n-ya likes this.
Awesomatix A800 x2, Awesomatix A700 x2, Gizmo GZ2, VBC D08
National Points Member 201
RollingChicane2 is offline   Reply With Quote
Old 07-22-2017, 02:52 PM   #2704
question about AT21+0.5S are they the same height as the AT21
eded1 is offline   Reply With Quote
Old 07-24-2017, 09:33 AM   #2705
Magnet Top's Avatar
Yes
Magnet Top is offline   Reply With Quote
Old 07-24-2017, 02:01 PM   #2706
Originally Posted by Magnet Top View Post
Yes
Thanks for your respons
Old 08-03-2017, 08:42 PM   #2707
Does anyone know what the size is of the OR155? I want to rebuild my dampers but can't seem to find any in stock anywhere.
Scargoes is offline   Reply With Quote
Old 08-04-2017, 02:17 AM   #2708
ID 5,0mm CS1,5mm OD 8,0mm
Oleg Babich is offline   Reply With Quote
Old 08-05-2017, 02:21 AM   #2709
Hello
anyone know if i can use shr mode on my Sawna m12 with Awesomatix AS-701L?
magstaff is offline   Reply With Quote
Old 08-05-2017, 08:15 AM   #2710
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by magstaff View Post
Hello
I run S5
magstaff likes this.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 08-07-2017, 09:59 PM   #2711
tandman's Avatar
Send a message via Yahoo to tandman
Anything new coming out before carpet season??? Should I be waiting to buy new kits??
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 08-07-2017, 10:02 PM   #2712
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Hell yeah lol
tandman likes this.
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 08-08-2017, 02:51 PM   #2713
hanulec's Avatar
Originally Posted by OVA View Post
Hell yeah lol
new Amtx stuff is usually a December / January thing if the future follows the past. i'm typically going to Snowbirds in Jan/Feb with a brand new car that i've never run in a large competition before. sometimes there is great success -- sometimes, not so much!
tandman likes this.
Old 08-08-2017, 07:18 PM   #2714
Trader Rating: 17 (100%+)
Prob be a car for asphalt. Since a lot of the new ones geared toward carpet. I love my a800xa cars. Own 3. Faster with these than my X-ray t4. Plus no traction rollover
Osiris 75 likes this.
Rcforlife13 is online now   Reply With Quote
Old 08-09-2017, 08:46 AM   #2715
dawgmeat's Avatar
Are you expecting AT78 + OR152 Damper Piston Set in the next shipment
dawgmeat is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Nerobro
