Like Tree4Likes
Old 11-30-2015, 08:48 AM   #121
skyball's Avatar
Originally Posted by patorz31 View Post
Use the side links from the AE 12r5.2. They are a little more flexible and forgiving when you hit something.
You could also try to cook (in hot water) the sidelinks a bit before installing. Never tried it on sidelinks, but it's an old trick to make platic parts more flexible.
[Sanwa M12][Awesomatix A800][Ronalds Yoke BD-7 2014][Roche P12 2016][Asso RC12R5.2][VBC LightningFXM]
skyball is offline   Reply With Quote
Old 11-30-2015, 05:09 PM   #122
Regional Moderator
disaster999's Avatar
Originally Posted by Gillblade View Post
Anybody know if the FX frontend could fit on the older F car?
The FX front end would fit directly on the F, but you will have no way of steering the car. The F integrates the steering servo into the front end where as the FX have the servo behind the front end with steering links.
disaster999 is offline   Reply With Quote
Old 12-03-2015, 05:37 PM   #123
Fredp1's Avatar
Went over the car and found the front ride height was 0.5mm lower on the left than the right. Measured and checked everything, no tweak anywhere. Only conclusion I can make is the lower arm pivot ball mount must be slightly angled.
Anyone have this issue?
Fixed it by replacing the 1.5mm FRP ride height spacer with a 1.0mm from the Flash 04. D-05-VBC-1016.
The shock had slop in the upper and lower mounting points. Replaced the shock lower eyelet and pivot ball with a associated ASC91448 part. Fits perfect and no slop. Also replaced the pivot ball on the top of the shock with one of the ball from the 91448 packet. Had to ream the top shock connector to get the new ball to fit nicely.
Looking forward to see how it runs tonight.
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 12-04-2015, 01:04 AM   #124
Got the FX in transit, need some help with a body. Can someone recommend a body that will fit with a standard shorty pack? Was looking at the standard tamiya F104 body that rcmart have on offer.
Cheers TJ
Timmo_821 is offline   Reply With Quote
Old 12-04-2015, 01:46 AM   #125
Regional Moderator
Cheers TJ
Protoform thirteen body would fit the FX quite nicely. There are enough clearance in the body that a standard shorty would fit. The Fourteen might fit the chassis as well but I have yet to try it.
The Tamiya should also fit the chassis as well.
Team Saxo duckbill would not fit the chassis. It will not clear the a standard shorty battery
Old 12-04-2015, 06:05 AM   #126
Fredp1's Avatar
+1 on the thirteen body shell.
My 13 year old drove the FX tonight with some very good results for his 2nd club night with the car and 2nd club night driving F1.
The car was a lot easier to drive this time staying close with the leader. Finished 3rd, 2nd and 2nd with about 1 to 3 seconds behind the leader.
Still a lot of learning on how to setup and maintain an F1 car.
The track is undercover with low grip coated concrete surface.
Ran kit setup except for the 100K oil in the side dampers. Ran Pit Shimizu tyres too.
Overall, very pleased with the car.
Old 12-04-2015, 06:15 AM   #127
Thanks for the replies, might grab the tamiya one and see how that goes and I'll post back on here later on
Old 12-04-2015, 07:32 AM   #128
AlexPate's Avatar
Trader Rating: 19 (100%+)
Fifteen fits as well.
Tamiya f60 probably won't fit with battery in transverse position
Also Tamiya bodies are 15-20 grams heavier
AlexPate is offline   Reply With Quote
Old 12-04-2015, 09:03 AM   #129
mtveten's Avatar
Trader Rating: 27 (100%+)
How much does a protoform bodies weight?
For comparison my f60 bodies with detail side pods attached weight 68-70 grams not counting wings. The vintage ferrari & Tyrell bodies are 48 and the Jordan 191 is 45g.
mtveten is offline   Reply With Quote
Old 12-04-2015, 09:05 AM   #130
AlexPate's Avatar
Protoform bodes with acrylic paint weight in around 35 grams.
Old 12-04-2015, 06:24 PM   #131
I believe the fifteen fits with low profile shorty packs only, as per the website. I'm after a body that will fit with the normal shorty packs in transverse configuration.
Old 12-07-2015, 01:48 AM   #132
Hello Guys,
I need some advices!
Im running the car with new Ride tires.
On corner exit, rear Wheel is always lifting.
Im using Ride soft springs in front,30k on both tubes and VBC soft springs for links.
Ill already harder front springs, harder links springs, but it's still the same...
Any idea?
Team Awesomatix / Team Roche / Team Corally / Wild Turbo Fan
nicoo2k4 is offline   Reply With Quote
Old 12-07-2015, 02:14 AM   #133
Regional Moderator
Are you running on asphalt or carpet? Is the track slippery or very grippy?
Try running soft springs in the front, and hard on the side and see if that helps with the lifting.
Old 12-07-2015, 02:33 AM   #134
Carpet high grip.
Old 12-07-2015, 04:09 AM   #135
sbd
Originally Posted by nicoo2k4 View Post
Carpet high grip.
You should do exactly the oposite to what disaster999 suggests.
A bit harder springs at the front and the softest available at the back. A softer oil in the side dumpers must be used also - try 10k.
sbd is offline   Reply With Quote
