Like Tree5Likes
Old 10-24-2016, 10:18 AM   #361
AlexPate's Avatar
Trader Rating: 19 (100%+)
Originally Posted by EDWARD2003 View Post
I took the VBC FXM out for it's first run on rubber tires using a 21.5 motor (never raced rubber F1). The car worked well for it's first outing and it was quite durable too. I had a few solid board taps and rollovers and the car came up unscathed.
I'll do a video to describe on the setup I used and overall thoughts about it's handling.
My estimation on damage reports.
Throw the axon spur out its too thin and put a xenon in. Much better spur.
The upper camber links changed and there is less slop on the king pin ball. How ever they king pin. Ball cups are shorter and the turnbuckle is the same length. 26x4mm turnbuckles should solve that issue.
Other than that the car is durable and fast.
AlexPate is offline   Reply With Quote
Old 11-02-2016, 09:33 PM   #362
EDWARD2003's Avatar
Yes, the Axon spur gear is delicate to say the least. Definitely worth putting in a different brand of spur gear for durability sake. The ''updated'' upper camber link ball and ball cup are no good, I reverted back to the Yokomo setup.
Check out my video on YouTube about other thoughts and opinions on the FXM!
https://www.youtube.com/watch?v=S_ySuR3tQ4E
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 11-02-2016, 10:11 PM   #363
AlexPate's Avatar
I have 4x26mm Lunsford turnbuckles in stock at gripworksRC.com That should make the updated king pin balls and cups work. I will test it this weekend.
Old 11-02-2016, 10:32 PM   #364
EDWARD2003's Avatar
The turnbuckle won't remove the slop from the upper ball and cup.
                 VBC 12M - D08 - FX
Old 11-03-2016, 07:23 AM   #365
AlexPate's Avatar
There was no slop in the upper ball and cup. The ball cup is just too short. Therefore there wasn't enough thread I
Engagement. In the mean time I reverted back to the fx ball cups and king pins and have no issues with the slop. Car still works great.
Old 11-03-2016, 08:02 AM   #366
EDWARD2003's Avatar
You must have a unicorn!
Both the FX and FXM upper ball cup and ball had too much slop. But, if you say there is no slop, I would say you're one of the lucky ones.
                 VBC 12M - D08 - FX
Old 11-23-2016, 01:38 PM   #367
Adam West's Avatar
Has anyone experienced the diff ball bearings seizing up on the shaft? Both my 3/8x1/4 flanged and 3/8x1/4 (enter bearing/closest to spur) bearings completely seized on the shaft. I had to forcibly remove(destroy) them. I discovered the problem after I noticed the shaft didn't spin/rotate as freely as it should. But, I did notice the FIT was extremely tight during the initial build!
Also, can someone recommend a strong/very durable replacement SPUR GEAR??
Adam West is offline   Reply With Quote
Old 11-29-2016, 05:22 PM   #368
i just got the tamiya thrust bearing from grip works and can't figure out how it goes in so i got bearing on the outside then bearing on the inside the two () then i put the thrust bearing on no plastic peice on the outside don't fit alex could you explain how it goes on please thanks in advance
ScottZ is offline   Reply With Quote
Old 11-29-2016, 05:31 PM   #369
EDWARD2003's Avatar
If the fit is extremely tight, I would just take some fine grit sandpaper and lightly remove some material. I had the same issue with my Associated 12R5.2. You can use a Panaracer spur gear or Yokomo's new spur gear.
                 VBC 12M - D08 - FX
Old 12-19-2016, 02:41 AM   #370
Fredp1's Avatar
When I first built my FX (about 12 months), the non flanged bearing was the wrong size. It wouldn't fit over the axle/shaft. The replacement was a perfect fit.
Hopefully you might just have some bad bearings.
I replaced the original steel rear axle with the carbon rear axle. This is a great improvement over the steel design.
With the steel axle, as you tighten the left wheel nut, it can put pressure on the left bearing as it pulls the hub against the bearing.
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 02-01-2017, 08:10 PM   #371
Trader Rating: 20 (100%+)
Can anyone please confirm if the Tamiya Thrust bearing will work with the FXM?
bee200sx is offline   Reply With Quote
Old 02-01-2017, 09:33 PM   #372
AlexPate's Avatar
Yes it will
Alex Pate. www.gripworksrc.com
Motiv Rc, Hobbywing, ORCA, Protoform,
VBC RACING, XRAY, ROCHE, AWESOMATIX, TEAM ASSOCIATED,
ARC,CRC,AVID,MCKUNE DESIGN, PROLINE, JCONCEPTS, GFORCE, MACLAN, R1WURKS
Old 02-01-2017, 09:39 PM   #373
Yes it will
Thanks for that AlexPete much appreciated.
Can you please share how you installed it or the order you have installed it in the FXM.
Old 02-01-2017, 09:56 PM   #374
AlexPate's Avatar
Red face
I use the 1:4x38 bearing then thrust bearing then spring washers
So
Thurstbeaing)()|nut
Use 3 spring washers for extra tension. It will stop the car from diffing out
Old 02-01-2017, 10:05 PM   #375
So
Thurstbeaing)()|nut
Awesome, thanks mate.
