Like Tree5Likes
Old 07-16-2016, 01:23 PM   #301
1spunspur's Avatar
Nice work Montros. Where did you find the Ti. to make these?
P./
1spunspur is offline   Reply With Quote
Old 07-18-2016, 03:44 AM   #302
GasGod's Avatar
I see most of you do not run a servo saver,,any issues with that?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 07-18-2016, 02:45 PM   #303
Slotmachine's Avatar
Send a message via MSN to Slotmachine
No no problems at all
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 07-18-2016, 05:51 PM   #304
Regional Moderator
disaster999's Avatar
stripped the gears on the savox servo tho.
disaster999 is offline   Reply With Quote
Old 07-18-2016, 06:04 PM   #305
I ordered the Ti from a group that makes medical products. It the ends they normally throw out. Keeps my cost down. The first weekend with the new king pins and even though I clipped the inside of a curb hard enough to yank the lower ball holder free from the carbon arm the king pin and e clip stayed secure.
The car ran so well I won the main. First time for that with this car. The suspension worked so well cornering was smooth as butter. Didn't realize how much the old e clip system was catching on the lower ball mount.
Montros is offline   Reply With Quote
Old 08-19-2016, 06:10 PM   #306
Trader Rating: 27 (100%+)
curious about the new FXM !
http://www.redrc.net/2016/08/vbc-int...-option-parts/
Awesomatix-Vbc-Hudy-Orca-motiv-Tsr-
pat5b is offline   Reply With Quote
Old 08-19-2016, 06:11 PM   #307
AlexPate's Avatar
Trader Rating: 19 (100%+)
Originally Posted by pat5b View Post
It should be out mid September, I have 5 on pre order. It will have the new 12m style rear pod. And a few other updates. I haven't seen the final product pictures so I don't want to speculate on everything
AlexPate is offline   Reply With Quote
Old 08-19-2016, 07:15 PM   #308
Loll! Only 1 minutes to reply!
Are you driving your FX as fast as the time you take to reply?
Old 08-19-2016, 07:26 PM   #309
AlexPate's Avatar
Faster. I've only lost one trophy race in the north west since it came out. And the car that won was another fx
Old 08-19-2016, 08:11 PM   #310
aracefan's Avatar
Trader Rating: 40 (100%+)
Sent you a PM, Alex. Thanks!
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 08-20-2016, 06:03 AM   #311
does anybody know if we can put an gear diff in the lighting fx that would be a lot better than the stock diff thiking of putting X-rays diff in otherwise thanks in advance
ScottZ is offline   Reply With Quote
Old 08-20-2016, 09:27 AM   #312
AlexPate's Avatar
The Fenix gear diff would probably work. But if your having troubles with your diff on high grip carpet. There are two sure ways to fix it. The first is by installing a Tamiya f104 thrust bearing and then install an extra thrust washer so you can get enough pressure that the car doesn't diff out in high grip. With out the thrust bearing the 5x11 bearing will fail with that much pressure
Thrustwasher)()|nut
I hope the image makes sense
Old 08-20-2016, 09:29 AM   #313
aracefan's Avatar
Thrustwasher)()|nut
This is the advice you need. Forgot you gave me the same advice, Alex. If you're running on carpet - this is what you must do. Don't really think the gear diff is necessary.
Old 08-20-2016, 09:32 AM   #314
AlexPate's Avatar
And now time for the shameless plug
Conveniently enough all of these parts are available at www.gripworksrc.com
Old 08-20-2016, 10:24 AM   #315
aracefan's Avatar
Should have mentioned that for you, Alex. I have ordered from Alex (GripworksRC) and not only does he ship quick, his customer service is the best I have experienced. Mostly because he knows his ****. He races on a weekly basis the cars he sells.
And btw ScottZ, the VBC ball diff is pretty high quality, just add those thrust washers and bearing and I think you would be more than happy - less maintenance too. And much easier to rebuild a ball diff than a gear diff (to me anyway).
Good luck with either, though.
