Like Tree4Likes
Old 05-22-2016, 03:43 PM   #256
blade072's Avatar
Trader Rating: 98 (100%+)
ok cool what I thought....yeah I have a couple of spare xenon spurs for now but will look into the Kawada at a later date...thanks
blade072 is offline   Reply With Quote
Old 05-23-2016, 04:55 PM   #257
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Well guess what diff fits the car? The xray X1 2016 car, but it is high priced..... trying to find one on a deal.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-23-2016, 05:40 PM   #258
EDWARD2003's Avatar
Save your money and just buy some -A ceramic differential balls, Square RC polished rings and extra Belleville washers. You can build up a beautiful differential with this setup.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 05-24-2016, 01:39 AM   #259
Regional Moderator
disaster999's Avatar
A Thrust bearing is a must. If not, be prepared to replace your bearing every single run.
Not even exaggerating
disaster999 is offline   Reply With Quote
Old 05-24-2016, 04:53 AM   #260
EDWARD2003's Avatar
Which bearing? I've have 500~600 laps with my FX with no issues with my bearings. Can you be more specific on which bearing we should watch out for?
                 VBC 12M - D08 - FX
Old 05-24-2016, 07:23 AM   #261
Hes talking about the outer right side 5x11 diff bearing, they are not meant to be loaded sideways. If you replace it with the tamiya thrust bearing you dont have that problem.
Old 05-24-2016, 08:48 AM   #262
Regional Moderator
As slotmachine said, Im referring to is the one inside the right side drive hub, just before the cone washes. Like slot said, in that particular situation, radial bearings are not designed to take an axial load. Depending on track, the bearing can be worn out in as little as one battery pack.
As many suggested, the tamiya thrust bearing seem to work well with the diff, but any 5x11x4.5 thrust bearing would work just as well. Ive ordered some from a chinese hardware store website for pennies each and havent found the need to replace it. Its typical to rebuild the diff after teach track session, but after that, the diff is buttery smooth again.
Old 05-26-2016, 02:55 PM   #263
Well the diff has finally freed up. I found out instead of using a drill to seat it in just use the throttle at a higher speed and they smooth up and get a little bit more locked.
Old 05-28-2016, 03:17 AM   #264
blade072's Avatar
hi all...
ran the fx for the first time today.......after the first run (on new tyres) i thought what the hell is this???....just spinning every time i tried to go around the corner...
anyway after changing a few things ie esc and radio settings, the diff from 16 balls to 8 balls and back again, after all that finally got the car to my liking...so far very impressed (driver not so much)....anyway might look at getting a carbon rear axle and maybe changing the pivot balls to reduce the slop as shown on this thread but apart from that.....loving the car....
here is a pic of my livery and wiring layout......
VBC Lightning FX-13271389_10154841477291509_370372303_o.jpg   VBC Lightning FX-13288234_10154837888186509_323501801_o.jpg
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
Old 05-28-2016, 07:28 AM   #265
AlexPate's Avatar
Trader Rating: 19 (100%+)
Originally Posted by blade072 View Post
hi all...
No carbon rear axles available
AlexPate is offline   Reply With Quote
Old 05-28-2016, 10:32 AM   #266
I recently machined a titanium version. Made a carbon version but didnt like it. Just feel the threaded insert on the left side is not going to last. Will run the new axle Sunday if weather holds out. Just wanted to reduce the rolling weight.
Montros is offline   Reply With Quote
Old 05-28-2016, 10:32 AM   #267
aracefan's Avatar
Trader Rating: 38 (100%+)
Congrats on getting the car working Blade! It is so much fun working a car in when you first get it on track. It's really my favorite thing to do. ha!
AP, I'm chomping a the bit to get my FX!! I have read through this entire thread, twice now.
Did the kit have the correct pivot balls when you opened it?
Again though, pumped to start putting this one together. . . Think I'm going to take my time on this one, as I have several other F1's and no one is really running them right now around here, and build it slowly and correctly. Seems like that will make a difference. Usually put a kit together in a day or two.
All give some, but some give all - thank you veterans for my freedom.
VBC is my new addiction - have Alex Pate at GripworksRC to thank for that!
aracefan is offline   Reply With Quote
Old 05-28-2016, 11:31 AM   #268
Default Carbon Axle
Pics of the carbon axle and the titanium one installed. The Ti version was turned down between bearings to get the wt down to the same as the carbon one.
VBC Lightning FX-100_2795.jpg   VBC Lightning FX-100_2797.jpg   VBC Lightning FX-100_2796.jpg
Old 05-28-2016, 08:50 PM   #269
blade072's Avatar
thanks alex...the carbon axle i saw must of been for the 12 scale cars........another question.....has anyone pondered using the F front end setup on the fx as described as an option in the manual?????? just curious
David Randall
Old 05-29-2016, 03:18 AM   #270
Hey Blade072 were you running at HH on saturday
jagman1 is offline   Reply With Quote
