Like Tree6Likes
Old 04-01-2016, 08:29 AM   #211
EDWARD2003's Avatar
Almost complete
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 04-02-2016, 09:26 PM   #212
Some final touches
Larry Brown
North Texas
L_Brown is offline   Reply With Quote
Old 04-03-2016, 02:22 AM   #213
Regional Moderator
disaster999's Avatar
Nice decals...you make them yourself?
disaster999 is offline   Reply With Quote
Old 04-03-2016, 06:57 AM   #214
I wish, found him on Facebook
https://www.facebook.com/Nicola670Pa...8948314815012/
Larry Brown
North Texas
Old 04-03-2016, 10:50 PM   #215
EDWARD2003's Avatar
Improving your FX steering linkages.
https://www.youtube.com/watch?v=_dcjsDqyS6o
                 VBC 12M - D08 - FX
Old 04-04-2016, 06:32 PM   #216
What o rings are those
Larry Brown
North Texas
Old 04-04-2016, 07:29 PM   #217
Regional Moderator
Ed did say they are Associated o-rings from a shock. Turn on annotations, he did post part numbers.
Yokomo #R12-18O
Associated #4663
Old 04-04-2016, 11:37 PM   #218
EDWARD2003's Avatar
Yokomo #R12-18O
Associated #4663
I am really looking forward to trying out this chassis. There are just a few hiccups, but then again I'm a little bit of a perfectionist (or I try to be ) when it comes to these builds.
I am super impressed how free the axle rolls on the bearings. I could never get it spin like this when I first built my YRF 001 or R12 kits.
Then again, not all kits are perfect.
                 VBC 12M - D08 - FX
Old 04-13-2016, 08:25 AM   #219
Regional Moderator
The stock shocks seem to work pretty well IMO...it's worlds better than that abomination through body shock bs they used in the lightningf
If you really wanna "upgrade" it, any short body TC type shock would work
Well just want to retract my comment on the stock shock. It has worked pretty well for me in the past, but when I broke down the car for a tune up, I noticed a lot of excessive play on the shaft esp when its fully extended. I can also see oil seeping out and covering the shaft.
Im not sure whats causing this but I dont remember it having this much play nor am I expecting this amount of play. Unless I come across a singular for F1, I dont think I will be shelling out money for a set of 4 just to replace the existing one.
Old 04-13-2016, 09:57 AM   #220
EDWARD2003's Avatar
When you mean excessive play are you referring to side to side play when fully extended? Could simply mean you need to replace the Orings and shock guide bushing. What I've found to work really well with VBC and other manufacture shocks is to use lots of Green Slime on the orings. Don't be stingy with it.
As for the through body shock, I built one today and it was a pain to build. But I took the time and through trial and error I found a really sweet method on how to build the shock. This shock is very smooth and consistent. Neat little design I might add.
I'll post a video on how I built it with zero rebound.
                 VBC 12M - D08 - FX
Old 04-13-2016, 10:13 AM   #221
Hi guys,
I am currently running VBC Flash 04 and I am very satisfied. i would like to jump into the new generation and I am looking between the common X1'16 or the VBC FX.
Is there any compatibility parts list between Flash 04 and FX (i have a big stock of spare parts !)
d3nisL is offline   Reply With Quote
Old 04-13-2016, 01:39 PM   #222
Trader Rating: 38 (100%+)
I had to steal some parts off of my Yokomo to build the front end but everything else seemed fine. In my rush to try it out, I never set the camber or toe on the front and never adjusted the tweak. With a fresh set of Sweep Mediums mounted up all the way around the car took a few laps to settle in. After that, it was by far the best handling F1 car I've seen at our local track. It turned in well and didn't try to swap ends. The only issue I really had was under braking as my brakes were set to 100%. After dialing them back a bit I'd say the car is easy to drive fast and am looking forward to getting to race it.
John Barr
On-Road: VBC WildFireD08; VBC Lightning10; VBC Lightning12; VBC Lightning10-235mm
Off-Road: Not likely
Special thanks to EMRFactory and VBC Racing.
linkless is offline   Reply With Quote
Old 04-13-2016, 05:53 PM   #223
EDWARD2003's Avatar
Originally Posted by d3nisL View Post
Hi guys,
Hello d3nisl,
It seems as if the front suspension, rear axle, and some other components are compatible.
                 VBC 12M - D08 - FX
Old 04-13-2016, 05:55 PM   #224
EDWARD2003's Avatar
That's great to hear, I wonder how better the car will handle once you get the front end all squared and set .
I'm glad to hear you're having a great time with the FX
Please post a picture of your car
                 VBC 12M - D08 - FX
Old 04-13-2016, 06:40 PM   #225
EDWARD2003's Avatar
Some final touches
Those chassis decals are so cool.
Have you had the chance to test the car out on the track?
                 VBC 12M - D08 - FX
