Like Tree4Likes
Old 03-08-2016, 06:39 PM   #196
AlexPate's Avatar
Trader Rating: 19 (100%+)
Originally Posted by L_Brown View Post
Sorry for all the questions but I'm new to on road.
What spur gears will fit, I want to get an assortment of them.
Xenon vss spur gears. Kawada
I'm sure there is more
AlexPate is online now   Reply With Quote
Old 03-27-2016, 08:50 AM   #197
EDWARD2003's Avatar
Made several VBC Lightning FX videos. Check out my YouTube channel.
More to come and excited to race this chassis.
Out of curiosity, can I run foams on this chassis with out any adjustments?
https://www.youtube.com/channel/UCPs...i28jqQ8iamnMqA
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 03-27-2016, 01:01 PM   #198
On the subject of the battery, has anyone tried thumb screws for the two screws that have to be removed in order to get the battery out?
L_Brown is offline   Reply With Quote
Old 03-27-2016, 04:51 PM   #199
EDWARD2003's Avatar
Upper pivot ball and cup fix.
https://www.youtube.com/watch?v=DO6ZfrBUvtU
Parts used
YF-10E
YF-15
                 VBC 12M - D08 - FX
Old 03-27-2016, 05:00 PM   #200
Fredp1's Avatar
Originally Posted by disaster999 View Post
Just to bring up the discussion about about using a thrust bearing in the diff a few pages back, I found a place that sells 5x11x4.5 thrust bearings for under 30 cents each and bought 10 of them. Installation is easy, you just replace it with the bearing inside the drive cup. The only thing I did was flip those cone washers backwards so instead of () from the manual, I installed them the other way round like this )( as recommended.
They work flawlessly with the diff and so far, and the diff action is really smooth. I will have to go run on the track a few times to see how much longer they last compared to a regular bearing, but Im having high hopes for them
Where did you get them from
Fredp1 is offline   Reply With Quote
Old 03-28-2016, 07:01 AM   #201
Regional Moderator
disaster999's Avatar
Im from Hong Kong and got them from China. Not sure if its worth paying for shipping if you only get the thrust bearing from them...
Been through 2 long practice sessions with the thrust bearing in the diff and I gotta say the diff felt as smooth as I first installed it. If it was the traditional bearing it would of be trashed already, but it held up pretty well.
disaster999 is offline   Reply With Quote
Old 03-28-2016, 07:19 AM   #202
Regional Moderator
Parts used
YF-10E
YF-15
thanks edward, the slop is SUPER annoying
Old 03-30-2016, 02:50 AM   #203
Yep works great!, found a hole bag of them from a PC case that I built a few years ago.
Only problem is they are silver and not black
Timmo_821 is offline   Reply With Quote
Old 03-30-2016, 02:52 AM   #204
You can also run a few beads of CA glue around the cup let it dry each time and give it a very fine sand once totally dried to smooth it out.
Seems like a design flaw as a few people have complained about this....
Old 03-30-2016, 04:31 AM   #205
EDWARD2003's Avatar
Yes, it's a minor hassle. However, it's an inexpensive fix and the parts should be easily available and last for a while. No kit is perfect, the YRF 001's left clamping hub was a huge annoyance.
So far the FX is a nice kit, still building it and learning a lot.
                 VBC 12M - D08 - FX
Old 03-30-2016, 11:22 PM   #206
EDWARD2003's Avatar
If you ever encounter a situation where the kingpin is rubbing the inner wheel (foam tire classes). Simply file down the bottom end of the kingpin. There's enough material to remove from the lower part of kingpin to create a gap so wheel will not rub.
                 VBC 12M - D08 - FX
Old 03-31-2016, 05:06 PM   #207
EDWARD2003's Avatar
It seems as if the ball ends and cups are rather loose on these kits.
But the fix is quite easy. Use Yokomo YRF 001 part #'s YF-10B and YF-10E.
These parts are a direct fit on both the shock shaft and mount. However, you will need to shave a flat spot on the rod end (YF-10B) in order for it to sit properly in the mount. Easy to do.
Also, using a piece of plastic from packaging and placing it between the ball and the shock end will eliminate slop. This is a common issue and fix for most dampers, Team Prime, Yokomo and so on.
Please trim off the excess plastic.
                 VBC 12M - D08 - FX
Old 03-31-2016, 07:00 PM   #208
If you wanted to upgrade the shock, what would be a good one to get.
Larry Brown
North Texas
Old 03-31-2016, 07:28 PM   #209
EDWARD2003's Avatar
Team Prime damper is nice option to go for. Yokomo R12 damper is good too, however, the VBC damper is really nice. I wouldn't worry about switching.
Old 03-31-2016, 07:30 PM   #210
Regional Moderator
The stock shocks seem to work pretty well IMO...it's worlds better than that abomination through body shock bs they used in the lightningf
If you really wanna "upgrade" it, any short body TC type shock would work
