About Zero-V discharger
Just want to find out my friends, how often do you use Zero-V discharger or similar discharger to recondition your battery?
I use the Novak Flatliner trays... Usually after every run,I'll dump off my cells using my spintec and then I'll tray them.
Discharge batteries with CDC V6 or Much More CTX, then I use my Integy 6s trays for 24 hours each battery. Then store till next meet.
The Integy 6s are the same design as the Much More Zero V and are about $20-00 cheaper!
then you will have at less 2-3 of the trays? cos each time it takes 3 days to recondition the battery on Zero-V discharger.
Before a charger(25min before) put the batteries on the tray, and then right before the charge, toss them on the charger, and there ready to go.
Do you need to unscrew the contact to the cell as soon as the light bulb goes out on that cell? Or just wait until all the light bulbs go out? I want all the cells to be as equalized as possible.
Thanks!
Thanks!
is there a big difference between the zero equalizer and the zero 6? And do most people run a few trays.
This is a good topic for newbs as my endless searching has me more confused than ever before.
There are no functional differences between the two trays, though.
