Old 09-01-2015, 01:18 PM   #1
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Default Power Distribution Block w/2S Output?
Does anyone make a Power Distribution Block with a 2S Output?
I just built a 72A power supply for my new iCharger 308Duo. Does anyone make a power distribution block that would also have an output that would be rated at 2S voltage so I could use my G-Force Motor Checker with it as well?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 09-06-2015, 02:34 PM   #2
X7 UBEC voltage regulator. HobbyKing has them. They take up to 24V input voltage and give a 2S output voltage. You could hook it up to your power supply directly in parallel with your iCharger.
ic-racer is offline   Reply With Quote
Old 09-06-2015, 04:05 PM   #3
Geezatec's Avatar
Look into MaxAmps.com. Under Charger/power supplies. Choose drop menu to Charge Accessories. Look into Balance Adapters and Multi-Balance cable. Your probably looking for Hyperion(Hyp). Adapter does 2S to 6s lipos.
Good Luck!!
Geezatec is offline   Reply With Quote
