Old 08-30-2015, 03:32 AM   #1
Coopz's Avatar
Trader Rating: 22 (100%+)
Default Good value 21.5?
Having a disappointing run with my Speed Passion, tried a dozen gear ratios but I just can't get enough power out of it, just lacks top end and low punch.
Looking at getting a Skyrc Toro or maybe a Hobbywing motor. Can't spend to much (joint account with the wife..). Any recommendations?
░▒▓█▀▄▀▄▀▄▀▄-ARCR Member-▀▄▀▄▀▄▀▄█▓▒░
Coopz is offline   Reply With Quote
Old 08-30-2015, 04:41 AM   #2
SagadSetup's Avatar
Trader Rating: 38 (100%+)
Hi
Have you looked into Turnigy Trackstar Motors?
I've been reading good feedback on them.
http://www.rctech.net/forum/electric...ar-motors.html
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 08-30-2015, 04:48 AM   #3
SteveM's Avatar
Trader Rating: 140 (100%+)
I have had three of the Hobbyking 21.5 motors and they were all solid performers and on par with most of the motors available. Hard to beat for the price.
SteveM is offline   Reply With Quote
Old 08-30-2015, 04:53 AM   #4
SagadSetup's Avatar
Hi Sir Steve!
I call that practical RC. What's in a name? Right?
Old 08-30-2015, 05:18 AM   #5
nexxus's Avatar
Trader Rating: 302 (100%+)
The Speed Passion is known to be a bit of a slug, the Trackstars do ok but you really need to gear them up, I've had to go to a FDR of around 2.9-3.0 to get them competitive next to some of the higher $ motors.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 08-30-2015, 06:11 AM   #6
sakadachi's Avatar
I'm interested too.
I read that the Thunderbolt with blue armature is pretty torquey and quick. It will still push you over $100 though..
Gotta pay to play, I guess.
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 08-30-2015, 03:28 PM   #7
Coopz's Avatar
I'll try the Turnigy. Are the red cans better than those X-car motors? I raced one for a while in superstock, lots of low down bite but the top end was a bit 'meh'. I geared it down but high temps became a issue.
Old 08-30-2015, 09:59 PM   #8
nexxus's Avatar
You want the Red Can ones, I've been trying a V2 21.5 and it seems to be a short stack motor, lower numbers on the motor tester but on the track it feels quite strong even with max timing and speed isn't too bad.
Old 08-30-2015, 10:07 PM   #9
midse's Avatar
They've released the V2 versions which will be Roar approved soon
midse is offline   Reply With Quote
Old 08-31-2015, 02:43 AM   #10
I've been using trackstar motor. I've had two of them. Both very good motors, but they do need to be geared down. Ive had no heat issues with a WTF fan.
Ryan
Tamiya M05
Spec-R S1
filippimini is offline   Reply With Quote
Old 08-31-2015, 02:58 AM   #11
nexxus's Avatar
Down or up?
I run an R1 Wurks at 4.0 FDR to be competitive a Trackstar I need to gear around 2.9 FDR
Old 08-31-2015, 03:56 AM   #12
Originally Posted by nexxus View Post
Down or up?
Sorry, Should have said geared up. I am running 2.74 for my local track to be competitive, where most are running 2.9-3.4.
Ryan
Tamiya M05
Spec-R S1
Old 08-31-2015, 05:29 AM   #13
That's interesting. Have you measured the stator yet? I would be interested in those numbers.
2uzferunner03 is offline   Reply With Quote
Old 09-02-2015, 09:43 AM   #14
eR1c's Avatar
Did you purchase and install the optional motor timing units?
My SP 21.5t "MMM" motor was anemic w/ the stock +10 sensor unit. I put the +40 sensor unit and the motor came to life. It is a serious power house.
eR1c is offline   Reply With Quote
Old 09-02-2015, 12:34 PM   #15
tobyzhang's Avatar
Try a + 30 timing board first. Speed passion motor are not slow by any means, but do need the timing board.
tobyzhang is offline   Reply With Quote
