Like Tree50Likes
Old 02-03-2017, 05:41 AM   #946
Trader Rating: 114 (100%+)
Here's a pic of my ride. Can't wait to run it this weekend!
Chris Furman is offline   Reply With Quote
Old 02-03-2017, 06:26 AM   #947
Trader Rating: 27 (100%+)
Nice lookin ride Chris have a good time. I'll be at BC running.
hobbyten is offline   Reply With Quote
Old 02-03-2017, 11:54 AM   #948
celt's Avatar
Well done, you're going to like it.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 02-03-2017, 06:27 PM   #949
espresso1967's Avatar
Trader Rating: 18 (100%+)
So what are you using for the rear? I use to have a unity tweak station but sold everything off and getting back into it.
Originally Posted by NutDriver View Post
Hobby King has a pan car setup station, but it's only for the front.
https://hobbyking.com/en_us/tracksta...up-system.html
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 02-03-2017, 07:03 PM   #950
I don't bother with a rear tweak station.
I set the car up like this:
1. set car on a level surface, front facing you
2. put coin on top of each front tire
3. with a pointed driver, lift up the front of the car from the bottom in the Center
4. which ever coin falls first, tighten the opposite tweak screw
5. adjust until front end lifts and both tires rotate at the same time
Old 02-04-2017, 02:02 AM   #951
Xray X10 2016
Anyone got a set up they'd care to share please
SlotCarRacer is offline   Reply With Quote
Old 02-04-2017, 05:44 AM   #952
celt's Avatar
Another method, if you have no coins because you've paid your entree fee...
Lift the front with a ball wrench in the center tweak hole. Spin both tires then slowly lower the front end. Watch which one stops first - then adjust accordingly.
Stan Garvin
Old 02-04-2017, 11:02 AM   #953
Originally Posted by SlotCarRacer View Post
Xray X10 2016
There is a lot of variation... driving style, track grip, track config, etc.
Are you having an issue? Post up some more detailed information.
Old 02-05-2017, 01:46 AM   #954
Haven't hit the track yet. Looking for a base setup for CRC rubber on using CRC carpet
Old 02-05-2017, 03:20 AM   #955
Which carpet-grey or new black. Black 45 spring instead of 50 that comes in the kit (front and sides). then go run.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-05-2017, 01:31 PM   #956
Got to run my WGT-r a bit at The Gate yesterday.
Two words.... Really FUN!
The car was pretty good for a first shake down run. Once I get a good 17.5 (hoping the TSR motors get back in stock SOOON!) I'll start picking on the setup some more. The HPI 7447 seemed to work well too.
BFast www.BFastrc.com "Feel the Diff"!
NORCAR www.norcarracing.com
Medina R/C Raceway Find us on Facebook!
ccm399 is offline   Reply With Quote
Old 02-05-2017, 02:34 PM   #957
Still Bill's Avatar
Yup. Gave up on using coins ages ago.
Something to add:
4a. and loosen (counter-clockwise) the other tweak screw an equal amount to not affect preload
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 02-05-2017, 10:13 PM   #958
Customworksking's Avatar
Trader Rating: 73 (100%+)
best body?
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 02-06-2017, 06:26 AM   #959
Originally Posted by Customworksking View Post
best body?
I have tested the following. Protoform PFM-10, Ford GT, McAllister C6 and MX-Stang. All on black carpet.
My picking order :
1. MX Stang for quick turning but edgy. Tire sidewalls are out of the body and you have to keep it off the walls. Best to run glued sidewalls with this one.
2. PFM-10, nearly as good as the MX and the tires are protected.
3. C6 but be careful with this one as it has a lot of front grip and you will need to adjust chassis front grip levels. I see people traction roll a lot with this one
4. GT, all around good grip levels but maybe too good. It would be good for someone new as it reacts a little slower. It would be my preference on pavement or a low grip track.
None of them are perfect and I would offer suggestions to each of the Mfg's to make them better if they asked.
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 02-06-2017, 01:35 PM   #960
My favorite so far has been the Protoform Mulsanne cut 10mm taller than stock so it doesn't look like a doorstop. It freed the car up with less overall down force than the Sophia I was running when I switched from foam.
Eddie_E is offline   Reply With Quote
