Like Tree50Likes
Old 01-10-2016, 08:59 PM   #436
TOM MAR's Avatar
I browsed the thread & did not find any feedback on the new CRC Carpet vs. the former version on the CRC Carpet.
Do the tires work better? More traction rolls? Etc...
If the Snowbirds will be on the new carpet, most of our racers have even seen it yet. Any pointers would be Great.
Tom
TOM MAR is offline   Reply With Quote
Old 01-11-2016, 06:28 AM   #437
NutDriver's Avatar
Trader Rating: 19 (100%+)
IMO, the new "black" carpet gives more grip. I ran 571/572 combo this weekend on my F1 car and still had more steering than I needed. This combo was quite pushy on my car on the gray carpet.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 01-15-2016, 04:09 PM   #438
liljohn1064's Avatar
Trader Rating: 17 (100%+)
My new/old club body. The last of my PF1499 C6R bodies. Not on the list as it was discontinued years ago.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 01-15-2016, 04:21 PM   #439
That body needs to make a comeback, it's awesome!
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
Old 01-16-2016, 07:07 AM   #440
lljohn1064 - where do you race this class? Is there activity for you in Wisconsin?
davidl is offline   Reply With Quote
Old 01-16-2016, 08:47 AM   #441
It is our biggest class here in Madison Wisconsin .
Old 01-16-2016, 09:13 AM   #442
I'm not saying expensive on the battery side as Hobbyking Ultimates will do the job. I'm still shaking down the V2 Trackstars, but not having much luck... yet. Time for bigger pinions!
I have a month running the Trackstar V2 stock spec and I found the same soft bottom end when I ran in my 1/12th. After racing it on 2S (buggy), I found it likes a lot more gear than any other short stack. I ended up 3 teeth up (48P) on the pinion from every other 17.5 buggy with 42*timing.
For 1S, try 40* timing and gear it hard like the old purple stripe Novak motors.
Don't be surprised to see 98~101mm roll-out.
Eddie_E is offline   Reply With Quote
Old 01-16-2016, 09:13 AM   #443
Johnn27's Avatar
Trader Rating: 72 (100%+)
Protoform definitely needs to re-release this body! Here is my WGT!
Johnn27 is offline   Reply With Quote
Old 01-16-2016, 02:30 PM   #444
Absolutely awesome!
Old 01-18-2016, 10:24 AM   #445
Default CRC Wheel Base
I put the F1 motor pod plates on my car to lower the ride height for the tires. The wheel base ended up around 3/8 inch longer than the stock wheel base. Any recommendations to return it to the stock wheel base?
Old 01-18-2016, 10:30 AM   #446
If you mount the front plate backwards and put the front A arms in the shortest wheelbase position, you will gain some of that back. This is why we shim the pod plates on the SE and LE
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 01-18-2016, 05:22 PM   #447
My ride height was 8mm with the stock SE pod plates so I would need a 3mm shim to get the rear of the car down to 5mm. So now my question is: Are you shimming that thickness? And does that mean the motor in your setup sits 3mm higher than it does in regular WGT trim?
Old 01-19-2016, 03:29 AM   #448
MarkBurgess's Avatar
World GT-R Rules and Discussion-10399367_10153235789641994_6800012225548724025_n.jpg
Counting down to the Snowbirds and my first time racing World GT-R.
My car is packed and ready to go, after a brief shakedown run in the UK. Lots of interest in the GT-R class from UK racers, and those that saw the car at the recent National (and pictures shown at the Reedy Race) were impressed.
Let's race!
MarkBurgess is offline   Reply With Quote
Old 01-19-2016, 07:28 AM   #449
Yes we are shimming it that far. You cannot feel it at all. Our new rubber car that is coming takes care of that problem. But if you were on the driver stand and I put down a car with the motor shimmed and a car without the motor shimmed up, you could not tell me which one was which at this speed.
Old 01-19-2016, 11:00 AM   #450
Thanks Dumper. Good luck at the Snowbirds!
