Like Tree39Likes
Old 02-10-2017, 08:21 AM   #976
Default Setup
Is there a site that has current setup info for these cars? CRC's site is outdated and there aren't any on petit rc.
blankenj99 is offline   Reply With Quote
Old 02-10-2017, 08:33 AM   #977
Dumper posted this a while back. Great starting point. Tune to track/driving style from there.
"Originally Posted by dumper View Post
As close to 5mm ride height as you can get
1/10th 45 front springs .590 kingpin length
1.5-2 degrees of camber
3/4 to full tire traction
5 degree caster blocks 2 or three shims forward
trailing axle, short wheelbase
red or white center spring
10k or less in the tubes
.45 or blue side springs just touching
200mm rear track width
rear ride height you can go up to 6mm if needed to get it to turn
Does your setup vary from this? What body are you running? Did you get all of the bump steer out? Any info you can provide will help......
Brian"
Hope that helps!
BFast www.BFastrc.com "Feel the Diff"!
NORCAR www.norcarracing.com
Medina R/C Raceway Find us on Facebook!
ccm399 is offline   Reply With Quote
Old 02-10-2017, 10:42 AM   #978
Brian"
Hope that helps!
Thanks!
Old 02-10-2017, 02:34 PM   #979
Sure. I didn't really do much though... Dumper posted the info.
Old 02-10-2017, 03:14 PM   #980
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
I'm gonna raise my rear height and give that a go.
Quick question for those that switched to the new GTR chassis, did it make a really big difference? I have the Gen X SE chassis. I think I'm going to convert back to foam since that is what it is designed for.
There's a kit at the track that is calling me name LOL
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 02-11-2017, 08:01 AM   #981
Trader Rating: 114 (100%+)
Any rule updates circulating? As in matching the power of WGTR to F1?
2S with 25.5T?
Chris Furman is offline   Reply With Quote
Old 02-11-2017, 08:23 AM   #982
Trader Rating: 27 (100%+)
2S with 25.5T?
I hope not everything fits great with 1s.
hobbyten is offline   Reply With Quote
Old 02-11-2017, 09:59 AM   #983
Still Bill's Avatar
Or...."I hope not. Everything fits great with 1s."
Ditto here.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-11-2017, 11:21 AM   #984
2S with 25.5T?
An old 13.5 with 1S or the newest low IR 17.5 with 1S matches the F1 setup exactly.
Eddie_E is offline   Reply With Quote
Old 02-11-2017, 11:26 AM   #985
2S with 25.5T?
No. 2s is not even on the horizon.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 02-11-2017, 12:54 PM   #986
1S 17.5 is about .6-.9 sec a lap slower than F1. So not exactly.... LOL
but close..
Old 02-11-2017, 12:57 PM   #987
Sounds good... was hearing people talk about it. Hope more jump Into this class!
Old 02-11-2017, 01:49 PM   #988
We have 7 to 9 at BC every race day.
Old 02-11-2017, 02:10 PM   #989
but close..
You need to try a Team scream or Motive MC2 motor.
Old 02-11-2017, 02:12 PM   #990
Take a look at Snowbirds lap times. They were off by quite a bit, I'm sure they ran good motors. :-)
