Like Tree35Likes
Old 12-08-2016, 09:13 AM   #886
Originally Posted by dawgmeat View Post
Is the Airtronics 94761Z servo good enough for this class
It can work. It is not known as the most durable servo out there........
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 12-08-2016, 09:15 AM   #887
Originally Posted by rmtr View Post
How many mm's were needed to achieve the 5 mm ride height?
Probably 3-4. Just get some tires on the car, get out your ride height gauge and start shimming. I don't have the exact measurements in front of me, but put some in and check it. The nice thing is that once it is done, it is done.
Old 12-08-2016, 10:47 AM   #888
What are people running for caster/reactive caster with the new rubber tires and new black carpet?
I'm running the GenX SE bone stock except for ride height shims.
Eddie_E is offline   Reply With Quote
Old 12-11-2016, 03:31 PM   #889
RoyB's Avatar
Trader Rating: 16 (100%+)
Am going to run a Trinity D4 1s in WGT-R. 48' X 100' carpet track. Anyone have any idea of timing to start with?
RoyB is offline   Reply With Quote
Old 12-11-2016, 03:55 PM   #890
Anywhere from 40- 45 degrees
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-11-2016, 04:25 PM   #891
Default servos
I JUST PURCHASED A CALANDRA X GEN 10 RT. DO YOU NEED A MICRO SERVO IN THEM, OR WILL A STANDARD SIZE SERVO WORK? IF I HAVE TO RUN A MICRO SERVO, WHAT DOES EVERYONE SUGGEST?
THANKS
JASON
Blues Hockey is offline   Reply With Quote
Old 12-11-2016, 04:38 PM   #892
RoyB's Avatar
thank you
Old 12-12-2016, 04:06 AM   #893
5 deg reactive and run as much caster as possible. If corner exit is not smooth reduce the caster one shim at a time. You may also want to raise the front roll center 2mm. CRC has a shim kit for that.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 12-13-2016, 11:02 AM   #894
THANKS
JASON
A mini servo (not micro) is suggested. Sanwa SRG-HR+HS, Spectrum A5040, JR 3717, KO RSX 12, Hitec 225MG, Futaba 9650 or BLS671.
Sanwa SRG HR (light, low, fast), Spectrum 5040 (affordable and excellent performance), JR3717 (great specs and very durable)
Team CRC is offline   Reply With Quote
Old 12-13-2016, 11:27 AM   #895
Company Representative
MikeMayberry's Avatar
The Hitec servo recommended for pan cars is the digital/coreless 7235MH. http://hitecrcd.com/products/servos/...-servo/product
Mike.
MikeMayberry is offline   Reply With Quote
Old 01-12-2017, 01:27 PM   #896
SWTour's Avatar
Slightly off-topic, but at a couple of events in 2016 we did some limited testing of a WGT-R based car on the high banked ENCINO VELODROME (concrete oval)
The testing went so well that we've created 2 new "SPEC" oval classes using the CRC WGT-R based tires
1 we'll call OVAL SPEC-R, it will be basically ANY Oval Pan Car with WGT-R tires (pre-mounts) with the McAllister NASCAR style Gen6 bodies.
the other we'll just simply call GT-R, it will use World GT type chassis w/ the WGT-R tires and a Protoform 200mm P37-N body.
Throughout 2017, we hope to test THESE cars on a few other track layouts as well, and use it as a complete "Oval Spec" package for multiple tracks in 2018.
GT-R Rubber Tire Class Rules
#ThanksCRC
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 01-15-2017, 02:20 PM   #897
Hi all,
So I stopped by and saw my old buddies at The Gate Saturday and somehow left with a couple WGT chassis ready to be made into one GTR car. When I got home a read through this whole thread to get a feel for what I needed to make the car into a GTR ready racer.
So after some research on the CRC site I believe what I have is an WGT-LE with Gen X-10 front end mount plates (not sure why). So my question is with these mount plates I have three wheelbase holes instead of the two on the LE and SE cars. So which should I use? I know Dumper says to flip the LE plates and use the short holes but if I go short is that the same as the LE mounts short?
I am using shimmed stock rear pods and my wheelbase with the front arms in the full short holes is right at 9.875. Does that sounds about right?
Thank in advance!
Chris
BFast www.BFastrc.com "Feel the Diff"!
NORCAR www.norcarracing.com
Medina R/C Raceway Find us on Facebook!
ccm399 is offline   Reply With Quote
Old 01-15-2017, 03:14 PM   #898
Default Front Wheel Chatter.
First race with a Calandra Gen-X 10 r/t and had an issue with the front wheels chattering on high speed corners.
I am running the kit springs in the front, 1* negative camber and the side walls ARE NOT glued.
Any suggestions???? Thanks
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 01-15-2017, 05:54 PM   #899
Trader Rating: 114 (100%+)
Hello all... just introducing myself to you all. Picked up a CRC R/T kit today from Larry's RC and planning on running at either Xtreme Carpet Raceway in Bay City or Hobby Stop West in Toledo.
Picked up a Spektrum Servo, Orion 1S Lipo, and Trinity Certified 1S 17.5 motor.
Now just trying to decide on a 1S ESC. I have never owned a HobbyWing product, was always a LRP guy.
Any feedback/suggestions/comparisons to the different 1S ESCs available?
Chris Furman is offline   Reply With Quote
Old 01-15-2017, 06:13 PM   #900
Hobbywing stuff is ood stuff. Their new v4 ESC is TINY!
https://www.amainhobbies.com/hobbywi...112401/p540791
If I was buying a new one this would be the one I would get.
I will be starting with a Turnigy Trackstar Gen2 1s ESC. Mainly because it came with the car I bought but also because until I get some practice it won't be the ESC holding me back! LOL Maybe after I get decent I'll upgrade.
Chris
