Like Tree35Likes
Old 10-11-2016, 06:12 PM   #826
Still Bill's Avatar
Per request for a pic. As raced at this year's IIC.
Using an Orca 1S ESC, PFM-10 body and aluminium body posts, the car is balanced side-to-side without any ballast weights. Weighs 1028 grams while minimum is 1025 grams.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-11-2016, 06:19 PM   #827
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
With the battery down the middle I had my esc in front of the motor under the damper tubes
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 10-11-2016, 06:38 PM   #828
jdob's Avatar
Originally Posted by BullFrog View Post
I personnely like the shotrest wires as possible. I would attempt to send pictures but I'm experimenting with the different battery positions. I orginally had the battery down the center. Now I'm trying the battery in the transverse set-up. With the battery down the middle I had my esc in front of the motor under the damper tubes.
Bill
Thanks guys! I had been planning basically the same set-up as you all have mentioned...Just need to get it done now and mount & paint a body...If anybody else has any chassis pics - please share them! Thanks again guys!
jdob is offline   Reply With Quote
Old 10-11-2016, 06:40 PM   #829
JEFFs SC10's Avatar
so as a consensus is everyone going much faster with the new chassis?
XRAY 2017 T4
Xray X12-17' GT12
Old 10-11-2016, 07:54 PM   #830
Still Bill's Avatar
I took both my conversion SE and a new R/T to the IIC.
For my initial testing at 702 Raceway, both cars were very similar in performance. However, afterwards at the IIC, I checked weights of them and found the SE was 40 grams underweight at 985 grams while the R/T was 1020 grams (before I replaced the body posts which added 8 grams).
So, after adding 40 grams to the SE conversion, the nod went to the R/T as my choice for the IIC. The R/T will also be my choice for asphalt racing because I intend to run (test?) with a transverse battery position for lower traction situations on asphalt.
Hope this helps.
Bill
Old 10-12-2016, 04:42 PM   #831
Jsaves's Avatar
Default Same set up?
Bill, did you run the same set up?
My ending set up on the LE was very soft and it handled well, but I did have the F1 rear slider pod which made it a tad long. This effected the steering in my opinion
Jsaves is offline   Reply With Quote
Old 10-12-2016, 08:19 PM   #832
Still Bill's Avatar
R/T was a tad more responsive than the SE with F1 rear slider pod.
Otherwise, both cars had the same motor, timing and gearing.
Bill
Old 10-13-2016, 04:48 AM   #833
Bill
The R/T brings the wheelbase back closer to the original. I had the conversion plates (three holes in the bottom) and it lengthened the wheelbase about 4mm. My car was the original GenX
The new car is more responsive especially with the battery transverse.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 10-24-2016, 01:51 PM   #834
http://www.rctech.net/forum/attachme...tc=1&d=1477342
http://www.rctech.net/forum/attachme...=1477342265206
Runs good. My only complaint is that we couldn't get them at our LHS till the Friday of qualifying in LV.
The Official World GT-R Rules and Discussion-fordgtdavidlee02-1-.jpg   The Official World GT-R Rules and Discussion-fordgtdavidlee01-1-.jpg
davidl is offline   Reply With Quote
Old 10-25-2016, 06:26 AM   #835
What would people's thoughts be if we were to go to 13.5 1s on tracks 80 feet and longer? Please be honest. If you want your opinion heard privately, feel free to PM Me......
I ran 13.5 at IIC for a practice, and I thought my car handled exactly the same, just a little quicker in a straight line. Granted that track was huge, and not the most technical layout ever, but it was fun.
Anyways, let us know what you think.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-25-2016, 06:54 AM   #836
We heard ya'll tried it at Vega. We tried it awhile back at our track. One of our complains from some of the guys was the class was to slow compaired with us running GT17.5 foam. We would probably get those drivers back if we went to 13.5.
My opinion would be if we ran both classes at the birds sort of like stock and modified in the old days that would be great. If you want we could try that down here on the birds track minus the subfloor at the Turkey race. Or we could try it again weekly on our smaller track with the subfloor.
I guess I'll need to order a stator for my motor to convert it to 13.5. We'll try it again .
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 10-25-2016, 07:17 AM   #837
TOM MAR's Avatar
It would have been if this had been followed up on when it was first suggested.I waited & waited & just bought a new 17.5. Other than that I'm fine with it.
TOM MAR is offline   Reply With Quote
Old 10-25-2016, 08:43 AM   #838
YoDog's Avatar
Trader Rating: 26 (100%+)
I've always been a proponent of sticking with the original recipe. WGT has been 13.5t 1s for quite a while so why change it just because the tires and bodies had changed. I think 13.5 adds more opportunity for passing for both large and smaller tracks. I ran mine with a 13.5 on the Fresno outdoor track and it was a lot of fun. Grant it, I was the only one with a WGT-R so I was forced to run with the USGT cars. I still took 3rd! Many of the races I've seen and viewed the results of, were just a freight train with practically no passing. The only passing was due to mistakes and then the driver who made the mistake had almost no opportunity to recover. Maybe have an FDR limit based on the size of the track and let the power plant be 13.5 for all tracks. That would be interesting. Top end for biggies and grunt for the smaller tracks.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 10-25-2016, 09:03 AM   #839
NutDriver's Avatar
Trader Rating: 15 (100%+)
I wish that it was 2s with a 21.5 or 25.5. With the low profile shorty 2s batteries getting close to 4000mah, I think it could work.
Has anyone tried 2s non-LCG shorty batteries with taller standoffs? I am concerned that it might significantly change the handling.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 10-25-2016, 12:01 PM   #840
MarkBurgess's Avatar
Body off chassis photo of my World GT-R car from the IIC. Routed wires to keep them as short as possible (especially to the LiPo) and keep the pod free side-to-side.
The Official World GT-R Rules and Discussion-14591593_310386899344361_3714214400046055731_n.jpg
MarkBurgess is offline   Reply With Quote
