Like Tree35Likes
Old 11-13-2015, 08:39 AM   #301
pilotsteve's Avatar
Default body posts
I put Parma PSE posts on my CRC car and they are thicker and stiffer and eliminated the body shuffling around.
pilotsteve is offline   Reply With Quote
Old 11-13-2015, 10:55 AM   #302
Originally Posted by starrx View Post
for the guys that are running the crc cars..are there any body mounts I can get that are stiffer..the ones I have are very flexible..& the body seems to bounce around & chatter in the corners...are there stiffer ones??
thanks
We have incorporated some stiffer posts from the oval world as well. The are not cheap, but they work awesome, are super adjustable and I don't ever see breaking them.
http://www.muddslidemotorsports.com/diovbopokire.html
We have them packaged with longer front posts so they work with the WGT-R bodies really well.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-13-2015, 11:02 AM   #303
NutDriver's Avatar
Trader Rating: 15 (100%+)
Thanks, Brian!
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-13-2015, 01:37 PM   #304
Lone Drifter's Avatar
It would be nice to have a standard class to run throughout the country. Like the old days , you could run pan car everywhere. I think 2 cell 25.5 would be good . The cars would have a good top speed but not be crazy fast. 2 cell 21.5 would be my second choice .
USVTA , USGT and Wheeler
TC7, TC6, T3 11 & 12, and TLR 22-4
Lone Drifter is offline   Reply With Quote
Old 11-13-2015, 01:42 PM   #305
scirocco14's Avatar
Agreed!
"But think of the children!"
lol....
Mark
Mark C. USVTA #115 TC4 & Xray T4 '13, USGT #115 Xray T4 '13
USVTA-F1 #115 F103/4 & F1R3 & WTF1 FC-16. Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway, Easley RC
scirocco14 is online now   Reply With Quote
Old 11-13-2015, 04:10 PM   #306
thanks for the info
starrx is offline   Reply With Quote
Old 11-13-2015, 09:58 PM   #307
Dork Missile's Avatar
Default steering set up
curious if anyone would like to share their steering set up pertaining to servo travel and expo? i can appreciate it might be a personal feel...but i'm curious?
Team Associated/Reedy/Schelle Racing/Go Go Hobbies/Toy Car Creative
B6D/B6/B64D/TC7/RC10R5.2
Dork Missile is offline   Reply With Quote
Old 11-13-2015, 10:43 PM   #308
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
What is the preferred body of this class? Finally saw a 1/10 pan car running the Pit tires and was hooked up outdoors. He was running a wedge body but regardless it was looking fun. Spec WGT tires never hooked up like this.
Josh-n-ya is offline   Reply With Quote
Old 11-14-2015, 01:29 PM   #309
Trader Rating: 46 (100%+)
We run on a very low traction carpet track and most other vehicle have a hard time with traction but these CRC rubber tires seem to have not problem with grip. We don't run wedge bodies. Just straight up gt bodies.
Regarding expo and steering setup I never use expo. First I adjust for EPA or travel. Then sub trim for centering. After that I just use dual rate to set how much steering throw I want.
v_squared is offline   Reply With Quote
Old 11-14-2015, 08:25 PM   #310
For the guys that are running crc cars..how soft are y'all setup??
I'm running whites all around & on the shock & 10,000 in the tubes...I was Told to try blue all around
Old 11-14-2015, 08:59 PM   #311
Im running a CRC SE .. I started with the set up i usually run on carpet .. one thing i noticed is the rear had alot of roll with the side white springs,,, I started stiffing up the rear purple springs and noticed the car carries more corner speed and is more stable intering and exiting the corners,with no grip problems ,, center shock im running 45 with red spring and raised the shock (front) almost level ,tubes im running 20k ,,. seemed to make the car on power and off power smoother with 1mm droop .. this testing was from carpet and asphalt .. Very happy with this set up sofar....
Mark Barden .
mb racer is offline   Reply With Quote
Old 11-14-2015, 10:42 PM   #312
Sounds good I may go stiffer
I'm running the crc gen x le..& the softer I went the smoother it got ..I drop almost a second a lap the softer I went...but it did seem like the front tires was acting as brakes in the corners..instead of rolling around the corner
Old 11-14-2015, 11:09 PM   #313
I had that same problem , corrected that by running less caster / and trailing axcel ... more testing tomorrow ....
Mark Barden .
Old 11-15-2015, 05:38 AM   #314
Cool report your findings please
Old 11-15-2015, 03:30 PM   #315
today was a little too stiff. on asphalt just changed the side springs back to white and the car was good .... plus it was cold today.. just a little more tuning and it should be good togo ..
Mark Barden .
