Like Tree38Likes
Old 11-05-2015, 04:14 AM   #226
Nego's Avatar
Trader Rating: 72 (100%+)
Converted one of my spec 17.5GT to try out the tires,here are some pics
Project X 1/10 pancar,17.5GT,BMI,yokomo,Associted F6.
Nego is offline   Reply With Quote
Old 11-05-2015, 04:16 AM   #227
Nego's Avatar
It's a BMI copper head 10 the body is a Toyota Supra.
Old 11-05-2015, 06:22 AM   #228
Originally Posted by Jsaves View Post
Brian,
What is the droop you are using with the long king pins in front?
Thanks and God Bless
.586 with the 1/10th scale springs and the stock white spacer
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-05-2015, 08:20 PM   #229
Jsaves's Avatar
Thank you very much Brian!
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 11-06-2015, 08:15 AM   #230
Donn's Avatar
Went testing at Cal Raceway in Orange, Ca on Tuesday and the car was good..just have to work on the high speed sweeper front end grip. A bit to pushy there. Off power, rotating in the corner and on power the grip was awesome Oh this is on asphalt. I have done a few setup changes and will be heading to Camarillo this sunday to run.
Donn is offline   Reply With Quote
Old 11-06-2015, 11:45 AM   #231
Hey DON ,, had a great time running with you tuesday at cal ..I have my car ready for testing tuesday .. so far on Carpet it doing well ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 11-08-2015, 01:07 PM   #232
Default Xray x10 conversion to WGT-R
Any X10 drivers out there use extra xra371050 2.5MM Graphite Mounting Plate Risers instead of round aluminum shims to adjust the front end for the new CRC GTR tires and wheels?
After 4 attempts of adding round alignment shims between the chassis and mounting arm plate using all 3 steel shim bars under the suspension arm, I still don't have the ride height down to 5mm. (It's currently sitting at about 7.5mm)
Is the chassis supposed to ride higher off the track using rubber tires compared to foam tires? If the chassis is sitting at 7+mm height compared to the 4.5mm height with foams, won't it handle differently?
Thanks for the help!
Ghartman581 is offline   Reply With Quote
Old 11-08-2015, 05:43 PM   #233
flyingm's Avatar
Just a heads up on bodies. There are four of our bodies on the approved list, however they are all for 190mm cars, so they most likely won't fit the WGT-R Pan Cars. Sorry. I guess we are out.
Sounds like a fun class. The new CRC tires are really cool.
Gary McAllister
McAllister Racing
flyingm is offline   Reply With Quote
Old 11-08-2015, 06:27 PM   #234
NutDriver's Avatar
Trader Rating: 15 (100%+)
Gary,
Your USVTA bodies, like the 1970 Camaro, 1969 Mustang, and 1968 Cougar are all WGT-R legal. Also the 1970 Firebird. We will be test fitting others, like the Jag, to see if they'll work. :-)
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-09-2015, 05:52 AM   #235
flyingm's Avatar
Hi Scott- I know the VTA bodies are legal, just don't know if they will be competitive with the winged bodies. Seems like the class is more oriented to modern Sports Cars, but there are no guidelines for the bodies. Thanks for your concern.
Old 11-09-2015, 06:47 AM   #236
Actually the VTA bodies are just as competitive as anything else. The bodies have to look like real cars. Any body approved for WGT is not legal. It is pretty cut and dry. Protoform is in the same boat as you, yet people are finding ways to run their "190mm" bodies.
Old 11-09-2015, 09:06 AM   #237
Are you guys balancing your tires?? Seems like i have out of balance tires when i throttle up and i'm sure this will effect handling...
junior1178 is offline   Reply With Quote
Old 11-09-2015, 09:21 AM   #238
Are fans allowed??
starrx is offline   Reply With Quote
Old 11-09-2015, 09:32 AM   #239
Originally Posted by starrx View Post
Are fans allowed??
Yes, we encourage people to cheer for you!
Old 11-09-2015, 09:32 AM   #240
Seriously though, if you feel like you need one, feel free.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
old_dude
