Like Tree39Likes
Old 10-26-2015, 11:58 AM   #196
vivo quevas's Avatar
Trader Rating: 18 (100%+)
I have a xray with a speed merchant conversion, and I have no steering on corner entry or exit inspite of having 12" turning radius. My car is unraceable. Any advise? I tried moving the battery forward working with rear track shock tension ride height 5mm in rear 4.8mm front. Associated .014 front $prings.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 10-26-2015, 01:26 PM   #197
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
not sure which model serpent it was, older I do know. Front I had 4mm of spacers under the arms ran asc .18 1-12 springs, 1.5 camber middle for caster on arm, about 1.5 deg toe out. rear was the circle type ride ht adjusters, put the highest one that was in the box, looks like the highest possible in, added 1mm between the rear pod bottom and the rear carbon lower plate. got the back to about 5.3 and front at 5.1.
Rollin out around 92mm seems to be pretty consistent for all of drivers.
Team Tekin, Team Scream, Paint By Mike, Team Mölzer Mowery Racing, EA Motorsports, Speedmerchant, TQ Wire
MMR Direct Minneapolis World Class Indoor Race Facility.
On Road and Off Road racing year round.
www.molzermoweryracing.com
http://www.facebook.com/pages/MMR/160679913944205?__req=9
Check out You Tube mmrswracing. Every qualifier and every main uploaded at the end of every race day.
ammdrew is offline   Reply With Quote
Old 10-26-2015, 01:27 PM   #198
ammdrew's Avatar
.014 is really soft, you may just be dropping to the ground and pushing.
Old 10-26-2015, 01:29 PM   #199
ammdrew's Avatar
You can hear the tire's in the grip
http://youtu.be/K6LWUG3K6GA
Old 10-26-2015, 02:55 PM   #200
I agree on the springs, probably coil bound. Try .018 or go to a soft 1/10 scale spring on a longer kingpin.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 10-26-2015, 05:25 PM   #201
I changed the springs to .014 fromv.020 no the chassis wasn't coil. Bound. It is something I'm not seeing I can setup a car but this has me perplexed.
Old 10-26-2015, 05:40 PM   #202
TOM MAR's Avatar
No marks from the front tires inside the body? Or could the sides of the body be hitting the carpet at speed?
Just throwing it out there as it has happened to me.
Tom
TOM MAR is offline   Reply With Quote
Old 10-26-2015, 06:58 PM   #203
Jsaves's Avatar
Default GTR TIGHT
Hey Guys,
I put the new tires on this weekend, once I adjusted the chassis for the tires, and the car drove very well. The problem is the car drove very tight. I tried to loosen it up by putting the hardest side springs and 50k in the tubes. Nothing worked
Ideas please?
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 10-27-2015, 06:36 AM   #204
We are running very soft. .45 or .50 side springs, .45 front springs with .586 kingpin length, 10k in the tubes, 1 degree of camber 3/4 to full front traction applied about 5 minutes before we run.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-27-2015, 02:46 PM   #205
Pretty much a ditto on my old Gen-X (the original) and it turns very well.
NORCAR @ The Gate
Old 10-27-2015, 03:56 PM   #206
Gravity Dodger's Avatar
I'm going to have to try this, my car has good initial turn in than proceeds to push bad.
Team Destiny, Power by TSR
Gravity Dodger is offline   Reply With Quote
Old 10-28-2015, 06:16 AM   #207
johnnywhopper's Avatar
this is exactly what I'm experiencing, but I'm running fairly stiff in the back.
I changed about every other possible thing on the car last Thursday including electronics and battery layout and kept getting slower all night.
This week, I'm going back to where I started, and softening up the rear end to mush and see what happens!
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 10-28-2015, 07:22 AM   #208
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I like a "softer rear" also...
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 10-29-2015, 06:09 AM   #209
you would, ya fruity s.o.b.! hahaha
Old 10-29-2015, 08:07 PM   #210
Default Other Mopar Cars
World GT-R Rules - Updated 9/2
- Chassis – 200mm pan car chassis (WGT car)
-Minimum Ride Height – 5mm
-Minimum Weight – 1025 grams
-Maximum Track Width - 200mm
- Tire and Wheel Rules – For the 2015-2016 season, Team CRC GTR rims will be the only rims allowed (Part #2310). The only front tires that will be allowed are Team CRC RT-1 (Part#2311), Team CRC Mounted RT-1 (Part#2314), and TCS fronts (Part#1031). The only rear tires that will be allowed are Team CRC RT-1 (Part#2312), Team CRC Mounted RT-1 (Part#2316), and TCS (Part#1032). Tires can be mounted “F1/Nascar” or “GT” style. If mounted “GT” style, the inner lip can be trimmed for clearance, however the molded letters (either CRC or TCS) must not be removed. The is no performance advantage to either mounting style, it is just for scale appearance. Stock inserts only. No Modifying inserts or “double stuffing” of inserts will be allowed.
-Battery – ROAR approved 1 cell (3.7v) hard case lipo. Voltage limit to be set by track (4.20-4.22)
-Motor – Any ROAR approved 17.5 turn brushless motor (Smaller tracks are encouraged to use 21.5)
-Rotor – ROAR approved tuning rotors are allowed
-Speed Control – Any ROAR approved spec class (blinky) speed control in “blinky” mode. NO RECEIVER PACKS. You may use a specific 1 cell speed control, or a two cell speed control with an external booster. Stock 2 or 4 cap banks that come with the ESC's only. There will be a limit of 10,000 micro farad on cap banks.
-Bodies – Bodies must be cut on the mold lines. No excessive cutting or lowering of the body is permitted. No lightening of the body is permitted. Wings and spoilers that are included with the body kits are ok if cut on one of the mold lines (if multiple mold lines are present). No additional aerodynamic aids are allowed. Backs of the bodies (including rear bumpers) are to be left in. No bodies that were designed for pan cars, no GTP, Daytona Prototype, IMSA, or bodies that look like 1/12th or 1/8th on road bodies with an integrated rear wing. Tires cannot stick outside the body.
-Race Length- Have fun with this. If 5 minute qualifiers and 5 minute mains fit in your race program, do that. If you want to do 8 minute races, do that. If you want to do shorter qualifiers and longer mains, do that. We have run 15 minutes with ease. Work with your race director to fit into the program. Run time and traction are not an issue for longer races.
-Fun- 100% Mandatory!
Approved Body list:
- Any body currently on the USVTA approved body list
- Protoform 1543-00 Cadillac ATS-V.R
- Protoform 1544-30 Chevy Camaro Z28
- Protoform 1532-30 Chevy Camaro ZL1
- Protoform 1542-30 PFM-10
- McCallister 307 MX Stang GT
- McCallister 233 Lexus IS
- McCallister 211 Jaguar XKR
- McCallister 282 Mercedes DTM
- HPI Racing 103886 Nissan 350z Hankook
- HPI Racing 106108 2011 Ford Mustang
- HPI Racing 106940 2011 Scion TC
- HPI Racing 108064 Scion FR-S
- HPI Racing 108370 2012 Porsche 911 GT3
- HPI Racing 109385 Nissan S13
- HPI Racing 109930 1969 Ford Mustang
- HPI Racing 17502 De Tomaso Pantera
- HPI Racing 17503 Chevrolet Corvette C6
- HPI Racing 17504 Ford Mustang GT-R
- HPI Racing 17505 Subaru Impreza WRC
- HPI Racing 17506 2004 Honda S2000
- HPI Racing 17515 Nissan Skyline R32 GT-R
- HPI Racing 17518 Nissan 350z Greddy
- HPI Racing 17524 Vertex Ridge Toyota Soarer
- HPI Racing 17525 Prova HPI Impreza
- HPI Racing 17526 1967 Chevrolet Corvette
- HPI Racing 17527 Porsche 911 Turbo
- HPI Racing 17530 Nissan Silvia
- HPI Racing 17537 Saleen Limited Edition
- HPI Racing 17538 Nissan GT-R (R35)
- HPI Racing 17539 Toyota Supra Aero
- HPI Racing 17540 BMW M3 E30
- HPI Racing 17541 Porsche 911 GT3 RS
- HPI Racing 17542 Lexus IS F
- HPI Racing 17543 2010 Chevy Caramo
- HPI Racing 17544 Alfa Romeo 8C
- HPI Racing 17548 BMW M3 GT2
- HPI Racing 30717 Weld JZX100 Toyota Mark II
- HPI Racing 30721 T&E Vertex Ridge JZX100 Toyota
- HPI Racing 30727 Weld X HPI Racing JZX100 Toyota
- HPI Racing 30730 Lexus LS430
- HPI Racing 30732 Lexus LS460
- HPI Racing 7038 Porsche 911 GT1
- HPI Racing 7039 Chevrolet Corvette
- HPI Racing 7049 Subaru Impreza WRC ‘98
- HPI Racing 7409 Nissan Skyline R34 25GT
- HPI Racing 7418 Porsche 911 GT3
- HPI Racing 7419 Dodge Viper GTS-R
- HPI Racing 7424 Toyota Supra
- HPI Racing 7427 Nissan Skyline R34 GT-R
- HPI Racing 7431 Mitsubishi Eclipse
- HPI Racing 7435 Porsche 911 Turbo
- HPI Racing 7438 Honda Civic Coupe SI
- HPI Racing 7440 Toyota Celica
- HPI Racing 7447 Pontiac Firebird Trans Am
- HPI Racing 7448 Mitsubishi Lancer
- HPI Racing 7449 Honda Prelude
- HPI Racing 7450 BMW M5
- HPI Racing 7452 BMW M3 GT
- HPI Racing 7455 Lexus GS400
- HPI Racing 7458 Subaru Impreza WRC 2001
- HPI Racing 7460 Chevrolet Camaro SS
- HPI Racing 7466 Toyota MR-S GT
- HPI Racing 7467 Nissan Skyline R34 GT-R
- HPI Racing 7473 2003 Dodge GTS-R
- HPI Racing 7475 Acura RSX
- HPI Racing 7478 Lexus LS430
- HPI Racing 7479 Nissan Silvia GT
- HPI Racing 7482 Mazda RX-7
- HPI Racing 7485 Nissan 350z Nismo GT
- HPI Racing 7486 Toyota Supra GT
- HPI Racing 7487 Porsche Carrera GT
- HPI Racing 7488 Mazda RX-8
- HPI Racing 7495 Ford GT
- HPI Racing 7499 HPI Racing Impreza
- Tamiya 51450 Raybrig Honda HSV-010
- Tamiya 51200 Xanavi NISMO GT-R
- Tamiya 51195 Raybrig NSX 2004
- Delta Plastik 0034 Subaru
- Delta Plastik 0037 Porsche 911
- Delta Plastik 0040 F50
- Delta Plastik 0049 Viper
- Delta Plastik 0050 Lotus Elise
- Delta Plastik 0052 CLK
- Delta Plastik 0055 Ferrari Enzo
- Delta Plastik 0056 Diablo
- Delta Plastik 0058 BMW M Coupe
- Delta Plastik 0402 Panoz Esp. GTR-1
- Delta Plastik 0405 Mustang
- Delta Plastik 0417 Ferrari F355 Challenge
Can the new 200mm SRT8 Challenger body and Delta Plastik 0043 Stratus be used?
MoparFanatic is offline   Reply With Quote
