Old 08-28-2015, 07:12 AM   #1
Smile 1/12 Pan Car Gearing
Hi all,
I'm a newbie to 1/12 pan car racing, and I have built a Tamiya RM-01 chassis and am wondering if you could advise as to what 64dp pinion and spur I should use with a 10.5 brushless motor (sensored).
Thanks very much
TamiyaCrazy is offline   Reply With Quote
Old 08-29-2015, 08:55 AM   #2
Drew Manzella's Avatar
Trader Rating: 28 (100%+)
That answer will depend on:
- What motor
- What size tires
- Your track size
Everything nowadays is done with rollout and/or final drive ratios. This is so you can calculate the gearing and maintain the same ratio as tire size changes.
No point in covering the theory and calculations here since this thread does it all very well:
how to calculate rollout
As for what a 10.5T target would be - I'd ask a local hotshoe at your track what they run.
SpeedMerchant Rev.8 Pro Team Tamale LCG | | SpeedMerchant Rev.8 Pro | Kyosho Plazma RA | | Kyosho ZX6.5 | Kyosho ZX5 FS2 SP | Kyosho RB6.5 | Kyosho MP9 TKI3 | Custom Works Enforcer G6 | B4.1 SS
Drew Manzella is offline   Reply With Quote
Tags
1/12, pan car, pan car racing, rm-01, tamiya
