Old 08-28-2015, 12:53 AM   #1
lethalsassonic's Avatar
Default Need help gearing my Tamiya trf 417x
Hey guys, I'm new to on-road and having some trouble figuring out gear ratios. My Tamiya TRF 417x is running well but it lacks overall punch and top-end speed. Other guys w/the same kit at the track have way more top-end and better acceleration. It's not the motor or esc because I have top-notch electronics. I'm using the stock 111 tooth 64 pitch spur, and a 38 tooth pinion. Someone at the track told me to order a Kimbrough 96 tooth 64 pitch spur gear and use a 46t 64 pitch pinion, but the Kimbrough spur doesn't fit properly, the holes won't line up to lock-in the pully holders. So the new spur is useless. My kit also came w/a 113 tooth Tamiya spur, and I have 3 aftermarket 3m racing pinions of 42t, 46t, and 51t. So is there a gear ratio with what I have that will give the car more punch? Or is there an aftermarket 96 tooth spur that will actually fit?
So...
I have: Tamiya 111 T spur, and 113 T spur
and: pinions of 38t, 42t, 46t, and 52t.
I would rather understand what I'm doing rather than just installing things and "seeing what happens..." Any insights appreciated!
Cars: Tamiya TRF 417x, HPI Ken Block WR8, EREVO Brushless
Heli's: Blade 300x, Blade 130x, Blade mcpx BL
lethalsassonic is offline   Reply With Quote
Old 08-28-2015, 01:01 AM   #2
what motor?
blinky or boosted?
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 08-28-2015, 01:38 AM   #3
Originally Posted by cplus View Post
what motor?
blinky or boosted?
Speed passion 17.5R, boosted I think. This is what I have: In the third pic you can see the Kimbrough spur which doesn't have holes that line-up w/the blue pulley holders (the male and female sides won't connect through this part).
Need help gearing my Tamiya trf 417x-1.jpg   Need help gearing my Tamiya trf 417x-2.jpg   Need help gearing my Tamiya trf 417x-3.jpg
Old 08-28-2015, 02:20 PM   #4
Massive difference in FDR requirements for 17.5 Blinky (in the 3's) vs Boosted (in the 5's)
If boosted, the advice you're getting re gearing won't mean squat if your boost/turbo settings are all wrong.
However, the ESC you are using is a non-timing one - no boost - so if you are racing against guys that are running boost, you have no chance to catch them in reality.
