Like Tree1Likes
Old 04-17-2017, 06:06 AM   #571
fdjizm's Avatar
crazy run! what motor is in there?
fdjizm is offline   Reply With Quote
Old 04-17-2017, 11:29 AM   #572
SWTour's Avatar
Default The BLOWOVER
Rich Slejmar made an attempt on Saturday for a little practice for the upcoming INSANE SPEED CHALLENGE -- His car thought it was a bird!!
https://www.youtube.com/watch?v=xEbxJJodOHg
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 04-17-2017, 11:06 PM   #573
fdjizm's Avatar
I'll give him an 8 on the launch, style points for flips and 6 on the landing.
SWTour likes this.
Old 04-18-2017, 05:10 AM   #574
New to this thread I'm curious if anyone has any knowledge on converting the center diff of a mugen mgt7 eco to a solid shaft. How are people doing it? Looking for a speed car in a couple of months and a center diff is not part of my dream kit lol.
illmatic94 is offline   Reply With Quote
Old 04-19-2017, 08:54 AM   #575
I bought a Serpent single speed shaft and used a lathe to bring the 8mm down to 5mm on a small portion of the shaft. By default, it's a bit long when fitting the MGT7 so you need to cut it down a bit. You can use any shaft really, but 8mm is the beefier option compared to 5mm. I bought some 8mm mod 1 pinions as the center drive gear. The hard part is getting the output drives to stay on at high speeds since the only thing holding them on is a set screw. The modified end of the shaft needs a really flat surface so that there's little vibration to walk the output drives off.
RepEvox is offline   Reply With Quote
Old 04-19-2017, 03:41 PM   #576
You flattened what part of the shaft? The part that holds the 2 speed in order to bolt on the pinion gear ( used as a spur gear)? Once you do that you put on the normal outdrives and bearings and everything should fall right in place?
Old 04-19-2017, 09:46 PM   #577
I bought this shaft and cut it down about 1/4 inch or so, but you'll have to find out how much needs to cut for your application. I brought the 8mm outer diamater on the cut side to 5mm exactly like the unmodified side. Then add flat spots somewhere on the 8mm region of the shaft for the spur gear adapter, pinion, whatever. You can figure out how to space it based on your motor and pinion. The other flat spot is on the 5mm end that I used a lathe for for the outdrive and set screw.
